@EliteMacx86 , try this, Layout-ID=3.
The Headphones switches automatically now. This is pretty good. But the distortion is still there. When using Jack Fix, no change at all. Used Layout ID=3
@EliteMacx86 , Mics not working?
Mic is working from beginning. But not like other Codecs. Now, it's working fine like it should. Internal Speakers is fine. Microphone is fine. But Headphones are having issues.
After few minutes, the Audio is not in Headphones. Sometimes it doesn't even switches to Headphones.
@Mirone, i've a new Codec from Analog Devices.
The Codec Dump is attached. Is a Desktop server.
AppleALC will be good.
Do you need to run jackFix to make it work again?
I run it couple of times. Sometimes, it works without the script. Sometimes, i need to run the script, plug, no Headphones, then unplug, run, plug and then it appears. And then i run it again but distorted sound. Sometimes, after removing Headphones, it doesn't switch to Internal Speakers.
Use AppleHDA Patcher, select ADI 1988B.
Are you sure?
A long time ago, i used AppleHDA for ALC1220 but no Audio so i didn't used it again. :p
BTW, what Layout ID?
wyattst99
