The same process works for microphones.
have you tried?
Yes, it works for both. I was about to Edit. When using my script, The Microphone works, but the voice is like i'm screaming and is too loud with some noise in the background.
I'm ready for the tests. Let me know if you want
@EliteMacx86 , Is the internal or external microphone not working well?
try this, Mojave Version use layout-ID=2, High Sierra Version use layout-ID=3.
With Mojave version, using layout ID=2, no Audio. Using High Sierra version, using Layout ID=3, Audio is same like earlier. No Headphones, The Mic quality is very poor and is too loud.
daemon6109
