Monterey sleep & brightness issues
MHD
HP ZBOOK 15 G4
Intel Core i7-7820HQ
Intel HD graphics P630 - NVIDIA Quadro M2200
Hi all,
After install monterey hakintosh on my laptop I'm successfully pathing wireless, bluetooth and trackpad to be work, but still have issues in sleep and brightness and other issue after every boot there is message say my laptop shutdown because of issue.
Hi all,
Your configuration is not as per the guide. I recommend you switch to OpenCore.
Reactions: MHD
Switched to OpenCore but it's same and there are more issues in addition to sleep and brightness:
Bluetooth and trackpad (scroll, selection) not working now
Computer shutdown because of problem message
When restart or boot again from hackintosh there is bios error time not correct
Still, the configuration is not as per the guide. The guide does not state to use any kind of Olarila SSDTs.
Moreover, incomplete PR files attached.
Where can I find the guide ?
Reactions: MHD
So I follow the guide but not booted
You cannot expect it to boot. There are several wrong things in the place.
-Remove SSDT-AWAC-DISABLE.aml and SSDT-PMC.aml from EFI/OC/ACPI directory and from config.plist
-Remove AppleALCU.kext, SMCBatteryManager, SMCLightSensor, SMCProcessor, SMCSuperIO.kext and from config.plist
- Add AppleALC.kext in Kext directory and link it under config.plist too.
You're still using the wrong config.plist file. Read the guide again.
Reactions: MHD
Believe me I'm trying to follow the guide, first I was use old version of OpenCore Configurator but now it's ok.
It's booted now but stuck on unable to get device memory.
Your config.plist doesn't matches.
delta385852
