Problems with my Hackintosh
embecuaanh
Lenovo ThinkPad X240
Intel Core i5-4300U
Intel HD Graphic 4400
10.13.x
Hi everyone,
My machine has successfully installed Hackintosh High Sierra but now have the following problems:
- Currently I can't use my Laptop's USB 3.0 ASMedia, plugged into the laptop can't be used
- Computer can't shut down completely, tried RehabMan's patches but didn't work. The phenomenon is that when shutting down, the laptop only turns off the screen but does not turn off completely and must be turned off with the power key
This is spec:
ASUS K53SD
CPU: Intel Core i5-2450M
RAM: 8GB
VGA: Intel HD 3000 + Nvidia Geforce 610M
LAN: Atheros AR8151
Wifi: Atheros AR9485
Thank you!
Hi everyone,
This is spec:
ASUS K53SD
RAM: 8GB
LAN: Atheros AR8151
Thank you!
No PR files attached.
Ok, sorry. This is EFI file:
Simply run sudo kextcache -i/ in terminal.
IOReg copy can be made using IOReg App.
I executed the above command and where is the kext cache file?
The result will be displayed in the Terminal itself. Simply Export it to txt file.
bobawoz
