Will my Desktop support Mac OSX Monterey? If so, could anyone plz make EFI for the hardware??
CreatorNewOSX
ASUS TUF GAMING Z490-PLUS (WI-FI) LGA 1200 (Intel 10th Gen) Intel Z490 (WiFi 6) SATA 6Gb/s ATX Intel Motherboard (Dual M.2, 12+2 Power Stages, USB 3.2 Front Panel Type-C, Intel WiFi 6 & 1Gb LAN, Aura Sync)
Intel Core i3-10100F 10th Generation LGA1200 Desktop Processor 4 Cores 8 Threads up to 4.30GHz 6MB Cache
Gigabyte GeForce GT 710 2GB DDR3 Memory Graphics Card (GV-N710D3-2GL)
  1. Other
Hi there!
I would like to know if my desktop is supported or not because I would like to install macOS Monterey on my PC, and I am a huge fan of Apple. The problem is their products are too costly!!
That's why I wanted to install Mac OS Monterey on my PC.
I will be giving detailed info, so no worries😊!
Specs:
Motherboard:
ASUS TUF GAMING Z490-PLUS (WI-FI) LGA 1200 (Intel 10th Gen) Intel Z490 (WiFi 6) SATA 6Gb/s ATX Intel Motherboard (Dual M.2, 12+2 Power Stages, USB 3.2 Front Panel Type-C, Intel WiFi 6 & 1Gb LAN, Aura Sync)​
Form: ATX
Video: HDMI
DP Network: Intel I219-V
GPU:
Gigabyte GeForce GT 710 2GB DDR3 Memory Graphics Card (GV-N710D3-2GL)​
CPU:
Intel Core i3-10100F 10th Generation LGA1200 Desktop Processor 4 Cores 8 Threads up to 4.30GHz 6MB Cache​
Audio Codec: ALC1220
I am also adding info for monitor and external webcam(with dual mics)
Monitor:
ACER 19.5-inch (49.39 cm) LED-Backlit Computer Monitor with VGA & HDMI Ports - K202HQL​
External Cam with Dual mics:
Lenovo 300 FHD Webcam with Full Stereo Dual Built-in mics - FHD 1080P 2.1 Megapixel CMOS Camera, Ultra-Wide 95° Lens, 360 ° Rotation - Flexible Mount (GXC1B34793)​
Also, in case if supported, could you plz provide EFI for the following hardware, for I am just a beginner and I don't want any mistakes to happen, or lose my computer😰. It would be a great help!!
Remember, this is a custom PC that I built myself.
In case any of you want any more info, do contact me here.
From,
CreatorNewOSX
Hi there!
Specs:
Motherboard:
Form: ATX
Video: HDMI
GPU:
CPU:
Monitor:
From,
CreatorNewOSX
The hardware is supported except for the Graphics Card. Although, the GPU can be patched, on Monterey.
You should start exploring the guides instead of demanding an EFI here.
Read here
Thanks so much for replying!❤️
wyattst99
