Location Services
Vinesh S Patel
Lenovo IdeaPad S540 15IWL
Instel WhiskyLake 8265U
Intel UHD620
10.13.x
My location services has suddenly stopped working. It was working smooth before two days. Don't know what has happened.
Are you using Ethernet/WiFi or any Dongle?
I'm using intel wifi. It was working before I've been using this for more than 5 months. It just stopped working two days ago.
Make sure the WiFi is set to en0.
I checked. It's set to en0. Still not working
Make sure you're logged into the right iCloud Account and Find My Mac is enabled. If it still doesn't work, log out and then try to log in.
I’m using the same iCloud account for six and I tried logging out and Logging in even yesterday I made a clean installation. Still not working.
Are location services turned on? Clear the old network preferences and remove logins from the keychain.
Yes, the location services are turned on in the privacy settings. And can you check remotely bro I'll pass you the team viewer is pass?
Okay. Provide your PR files to check further.
Unfortunately, that's not what forums is designed to as you're not availing a paid service here.
raymondleung416
