Anyway to Enable Gigabyte 6600xt in Mac OS Big Sur 11.5.2
KS1771
Z 490 VISION D
Core i9 10850k
amd 6600xt
10.13.x
Any method you can suggest , to Enable Gigabyte 6600xt in Mac OS Big Sur 11.5.2 , using a Fake ID ....
I have enabled the AMD RX550 2 GB card using a similar method , so asking for your help !!! :-)
I have enabled the AMD RX550 2 GB card using a similar method , so asking for your help !!! :)
No, it doesn't supports. Fake ID approach is not applicable to every hardware.
Any possibility of it being supported in Future Mac Os Updates ? Purchased a card thinking RDNA2 support was ok from 11.4 .... Total foolishness on my part ....
Always consider checking the compatibility first. We already have a thread for AMD users.
raymondleung416
