[Solved] Random hang-ups and kernel panic on MacOS BigSur 11.4 and Installer (Intel X299)
Set Kernel cache and architecture to Auto. Make sure memory settings are defined correctly.
I use restrict events to set memory and it's working
Ensure you're having suggested BIOS settings.
I have. CFG lock disabled, CSM disabled , Legacy USB Auto, Thunderbolt on PCIEX16_4, fast boot disabled, OS Type: other etc. BTW page with bios settings is broken nearly all of tables are empty
An update is going on for the forum and a lot will be changed in the upcoming days.
- ResetLogoStatus is still not removed.
- npci=0x2000 is not enabled.
Also, try with TB SSDT disabled.
xmax114
