Titan Ridge Thunderbolt on Hackintosh
PTuser
x79-up4
radeon wx4100
10.13.x
  1. Mac Pro
Hi - I am running Catalina 10.15.6 and have installed a titan ridge card flashed with dsm firmware on my non header machine. with the modded tb header pin fix. All TB devices I have are working except for the most important one, which is a Focusrite red range thunderbolt audio interface. This device is seen in the system in sys profiler and I have green Thunderbolt lights on the device . It can be controlled by thunderbolt but it wont work with system audio. I tried this device in a mac mini with tb2 and it worked fine so something is not right in my implementation. Im looking for some help to find the solution. I took IO reg screenshots of the working mac mini and my hackintosh and there are some differences however Im not clear on how to edit SSDT or other solutions
Hi - thanks for your message - I did read that - I thought this may be a bit different given the device is seen hence the post - however I will post my findings on that thread....
Sure.
Sorry for hijacking this thread, but what are the right BIOS settings after flashing the card, and do i need an SSDT? Can't get my UAD interface to work at higher sample rates than 48Khz without noises
You should reading the thread linked below.
Reactions: iDon't
Jycs
