MSI Z590I UNIFY Guide featuring Intel Core i9-10900F, Thunderbolt 4 and AMD RX 5700XT GPU using OpenCore. This guide can be used as a reference for any Z590 Motherboard chipset with very few changes.
Components
MSI Z590I UNIFY LGA 1200 Motherboard with Thunderbolt 4
Already Owned
Intel Core i9-10900F 10th Gen Comet Lake Desktop Processor 12MB Cache 2.9 GHz
Corsair Vengeance RGB DDR4 3200MHz 64GB RAM (2x16GB) ()
ADATA - 250GB PCIe NVMe - M.2 Internal SSD (MZ-V6E250BW)
Fractal Design Define 7XL (CC-9011078-WW)
LG 32" Full HD IPS Monitor with HDMI, and Display Port (LG 22MP58VQ-P)
EVGA 600 BQ, 80+ BRONZE 600W Power Supply 110-BQ-0600-K1
Dell KM636 Wireless Keyboard & Mouse Combo
Comments
The Build
As the new 500 series Motherboard are out, with Thunderbolt 4 so i decided to test Thunderbolt 4. The idea of this build is to use Built-In Thunderbolt. The idea of this build is compact, paired with an i9 10900F running @ 2.9GHz stock speed, having a AMD RX 5700XT 8GB from Sapphire, good power supply with 600W, normal power consumption and a solid performance packed in ITX Build.
Already have a build with MSI Z490I UNIFY and same amount of PCIe slots were needed so the ultimate choice was Z590I UNIFY. It's an ITX motherboard offering support for 10th and 11th Gen. CPUs along with the Thunderbolt 4 support. The motherboard offers built-in Type-C Display. A solid audio codec (Realtek ALC4080), 2.5Gb/s LAN, PCIe 4.0 support for faster data transfer rate. Along with all these, the motherboard supports various features.
Summary
FeaturesStatus
GraphicsYES
Built-in AudioYES
DP/HDMIYES
DP/HDMI AudioYES
EthernetYES
WiFi/BTYES
AirDropYES
HandoffYES
Thunderbolt 4 HotplugYES
Power ManagementYES
App StoreYES
iMessageYES
FaceTimeYES
iCloudYES
USB 2.0, 3.0, 3.1 and USB Type-C PortsYES
Not working
Everything works like a charm.
Bootable Media Creation
2. Plug USB to your system.
4. Close Disk Utility.
5. Open Terminal and type:
6. Enter your password
  • At this point, the bootable USB can be only used to boot Mac only. In order to boot the computer using the USB, follow the steps below.
Preparing OpenCore Bootloader
DirectoriesDescription
DocsContains documentation, change log, a sample config.plist, and ACPI Samples for OpenCore.
IA32Contains OpenCore EFI, 32-bit OpenCore Boot Loader.
UtilitiesContains several utilities.
X64Contains OpenCore EFI, 64-bit OpenCore Boot Loader.
Adding Required SSDTs
SSDT NameNotes
SSDT-AWAC
  • This SSDT serves 300 series RTC patch.
  • This SSDT is required for all 400 series Motherboards.
SSDT-EC-USBX
  • This SSDT fixes EC and USB Power.
  • This SSDT is required for proper USB Power.
SSDT-PLUG
  • This SSDT enables Power Management function.
  • This SSDT is required for a proper CPU and GPU Power Management.
Adding Required Drivers
Driver NameRequiredNotes
OpenRuntime.efiYES
  • Runtime driver including several other drivers merged such as ApfsDriverLoader.
  • OpenRuntime.efi is a replacement for AptioMemoryFix.efi driver.
OpenHfsPlus.efiYES
  • Provides reading of HFS+ Volumes/drives in OpenCore Boot Picker.
OpenCanopy.efiOptional
  • Provides GUI functionality for OpenCore Boot screen.
  • This driver is required if you need GUI or theme for OpenCore.
AudioDxe.efiOptional
  • Provides Boot Chime support.
  • Only required if you want to use Boot Chime
3. From the EFI/OC directory, just keep the above drivers and delete rest of the drivers.
  • All the drivers can be found at: X64/EFI/OC/Drivers
Adding Required Kexts
Kext NameRequiredNotes
LiluYES
  • Provides arbitrary patching.
VirtualSMCYES
  • Emulates Apple hardware. VirtualSMC is a successor of FakeSMC.
  • This kext requires "Lilu.kext" to function.
WhateverGreenYES
  • Provides GPU patching on macOS.
AppleALCYES
  • Provides Audio support on macOS.
NVMeFixYES
  • Provides NVMe Power Management.
USBInjectAllYES
  • Enables USB ports for mapping USB ports further.
  • It's advised to map the USB ports during the post-install for a better USB speed, improved sleep/wake and hotplug.
XHCI-unsupported.kextYES
  • Enables Unsupported USB ports.
FakePCIIDYES
  • Provides support for Intel Ethernet Controller.
FakePCIID_Intel_I225-VYES
  • Enables Intel Family onboard Ethernet Controller.
  • This kext requires "FakePCIID.kext" to function.
1. Download the above kexts.
Notes
  • Do not download the project files. The pre-built binaries/downloads are available in the README.md section. Make sure you read it carefully.
  • Use the kext from RELEASE folder and RELEASE.zip file.
  • Do not place unnecessary kexts here. It might prevent booting the installer.
  • Only use basic kexts which is required to boot off the installer. You can install the rest required kexts at the time of post-installation.
  • The VirtualSMC package includes Battery and Sensors plugins (SMCBatteryManager.kext, SMCDellSensors.kext, SMCLightSensor.kext, SMCProcessor.kext, and SMCSuperIO.kext). You do not need these kexts for booting the installer.
ACPI>Add
SSDT NameNotes
SSDT-AWAC
SSDT-EC-USBX
SSDT-PLUG
ACPI>Patch
Table Signature*FindReplaceCommentEnabledNotes
DSDT5045475047465830Rename PEGP to GFX0 (Graphics)YES
  • Renames PEGP to GFX0 for a better power management.
  • This rename is required for implementing discrete GPU Power Management.
DSDT48454349494D4549Rename HECI to IMEI (PAVP)*YES
  • Renames HECI to IMEI for PAVP services.
  • This rename is required for implementing PAVP services.
  • This rename fixes iTunes/App Store Content Access problems and also enables Content playback.
DSDT4D45495F494D4549Rename MEI to IMEI (PAVP)*YES
  • Renames MEI to IMEI for PAVP services.
DSDT4844415348444546Rename HDAS to HDEF (Audio)YES
  • Renames HDAS to HDEF for Audio.
  • This rename is required for implementing Audio Function.
Booter>Quirks
QuirksValueNotes
AvoidRunTimeDefragYES
  • Fixes certain UEFI runtime services such as date time, NVRAM, power control, etc.
DevirtualiseMmioYES
  • Remove runtime attribute from select MMIO regions.
  • This option reduces stolen memory footprint from the memory map by removing runtime bit for known memory regions.
EnableSafeModeSlideYES
  • Patch bootloader to have KASLR enabled in safe mode.
  • This quirk requires ProvideCustomSlide to be enabled.
ProvideCustomSlideYES
  • Provide custom KASLR slide on low memory.
  • This option forces macOS to use a pseudo random value among the available ones.
RebuildAppleMemoryMapYES
  • Generates Memory Map which is compatible with macOS.
SyncRuntimePermissionsYES
  • Update memory permissions for runtime environment.
ProvideMaxSlide0
  • Provide maximum KASLR slide when higher ones are unavailable.
Note:
  • The values which have been not discussed above, that will remain disabled.
DeviceProperties
This section is used for adding device properties. This includes PCI Devices information such as Graphics, Audio, WiFi, Ethernet and other controllers. The following changes are needed.
DevicesKeyValueTypeNotes
  • PciRoot(0x0)/Pci(0x1B,0x2)/Pci(0x0,0x0)
device-id
  • F2150000
DATA
  • Sets Device ID for Ethernet.
F2150000
  • Recommended for Intel i225-V 2.5GBe Ethernet chip.
Kernel>Add
ArchBundlePath*ExecutablePathPlistPathEnabledNotes
AnyLilu.kext**Contents/MacOS/LiluContents/Info.plistYES
AnyVirtualSMC.kext**Contents/MacOS/VirtualSMCContents/Info.plistYES
  • VirtualSMC is a successor of FakeSMC.
AnyWhateverGreen.kext**Contents/MacOS/WhateverGreenContents/Info.plistYES
AnyAppleALC.kext**Contents/MacOS/AppleALCContents/Info.plistYES
  • Enables onboard/built-in Audio.
AnyUSBInjectAll.kextContents/MacOS/USBInjectAllContents/Info.plistYES
  • Enables USB ports.
  • It's advised to map the USB ports during the post-install for a better USB speed, improved and sleep/wake.
AnyXHCI-unsupported.kextContents/Info.plistYES
AnyFakePCIID.kextContents/MacOS/FakePCIIDContents/Info.plistYES
  • Required for FakePCIID_Intel_I225-V.kext
AnyFakePCIID_Intel_I225-V.kextContents/Info.plistYES
  • Enables Intel i225-V Ethernet Chip
Notes:
  • All the plugins must load after loading it's dependencies otherwise the kext will no longer function even when loaded in OS X/macOS.
  • The mandatory kexts must be loaded in sorted order as shown in the above table.
  • *Indicates BundlePath i.e. Name of the Kext
  • **Indicates mandatory kexts.
  • All the added kexts must exists in the EFI/OC/Kexts directory.
  • The options which have been not discussed above, that will remain untouched.
Kernel>Scheme
OptionsValueNotes
FuzzyMatchYES
  • Enables checksum ignore with kernel cache instead of using latest cache available.
  • This setting allows matching the latest kernel cache with a suitable architecture when the kernel cache without suffix is unavailable, improving macOS 10.6 boot performance on several platforms.
KernelArchAuto
  • Determines Kernel Architecture.
KernelCacheAuto
  • Determines Kernel Cache.
Kernel>Quirks
QuirksValueNotes
AppleCpuPmCfgLockYES
  • Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in AppleIntelCPUPowerManage- ment.kext, commonly causing early kernel panic, when it is locked from writing.
  • Enable this quirk if you cannot disable CFG-Lock in BIOS/UEFI.
AppleXcpmCfgLockYES
  • Disables PKG_CST_CONFIG_CONTROL (0xE2) MSR modification in XNU kernel, commonly causing early kernel panic, when it is locked from writing (XCPM power management).
DisableIoMapperYES
  • Disables IOMapper support in XNU (VT-d), which may conflict with the firmware implementation.
  • This option is a preferred alternative to deleting DMAR ACPI table and disabling VT-d in firmware preferences, which does not break VT-d support in other systems in case they need it.
  • Enable this quirk if you cannot disable VT-d in BIOS/UEFI.
PanicKNoextDumpYES
  • Prevent kernel from printing kext dump in the panic log preventing from observing panic details.
PowerTimeoutKernelPanicYES
  • Disables kernel panic on setPowerState timeout.
  • Fixes kernel panics related to power changes with Apple drivers in macOS Catalina, most notably with digital audio.
XhciPortLimitYES
  • Enables 15 port limit patch.
  • This quirk is a temporary solution and is advised to map your USB ports during post-installation.
DisableRtcChecksumNO
  • Prevents AppleRTC from writing to primary checksum (0x58-0x59). Required for users who receives safe mode or BIOS reset error after reboot/shutdown. Mainly required for ASUS Motherboards. Do NOT use this quirk is you don't have such encounters.
DisableLinkeditJettisonYES
  • Disables __LINKEDIT jettison code.
  • Provides more reliable performance without keepsyms=1
  • This quirk is required for macOS Big Sur.
Note:
NVRAM>Add
UUIDKeyValueTypeNotes
7C436110-AB2A-4BBB-A880-FE41995C9F82boot-args
  • -v
  • debug=0x100
  • keepsyms=1
  • alcid=11
STRING
  • Adds boot args which provides several functions.
-v
  • Enables verbose mode. Helpful to track the installation progress or when booting.
debug=0x100
  • This disables macOS's watchdog which helps prevents a reboot on a kernel panic.
keepsyms=1
  • This is a companion setting to debug=0x100 that tells the OS to also print the symbols on a kernel panic.
  • This can give some more helpful insight as to what's causing the panic itself.
alcid=11
  • Sets Layout ID = 11 for Onboard/Built-In Audio.
csr-active-config
  • 00000000
DATA
  • Defines SIP type.
00000000
  • Enables SIP completely. (0x0)
  • It's advised to configure SIP via recovery using "csrutil."
  • For more information on SIP, check the SIP disabling guide.
prev-lang:kbden-US:0STRING
  • Sets Keyboard language.
PlatformInfo
Suggested SMBIOS
SMBIOSCPU
iMac 20,1Intel Comet Lake for i3 and i7
iMac 20,2Intel Comet Lake for i9
DataHub
OptionValueNotes
Add this section in config.plistYESAdds DataHub field
Generic
OptionsValueNotes
Add this section in config.plistYESAdds Generic field
from SMBIOSYES
ProcessorType0
  • Sets SMBIOS Processor Type.
  • This will override your actual CPU type.
  • It's recommended to set this option to "0" to detect the original CPU by macOS instead of using SMBIOS CPU Type.
SystemMemoryStatusAuto
  • Indicates whether system memory is upgradable in PlatformFeature. This controls the visibility of the Memory tab in About This Mac.
Auto
  • Use the original PlatformFeature value.
  • It's recommended to set this option to "Auto."
Upgradable
  • Explicitly unset PT_FEATURE_HAS_SOLDERED_SYSTEM_MEMORY (0x2) in PlatformFeature.
Soldered
  • explicitly set PT_FEATURE_HAS_SOLDERED_SYSTEM_MEMORY (0x2) in PlatformFeature.
SpoofVendorYESSets SMBIOS vendor fields to Acidanthera
PlatformNVRAM
OptionValueNote
Add this section in config.plistYESAdds PlatformNVRAM field
For more information on Comet Lake config.plist, check the post linked below.
SMBIOS
OptionValueNote
Add this section in config.plistYESAdd SMBIOS field.
Installing OpenCore EFI
2. Copy the EFI from your working directory to EFI partition of your Bootable USB Flash Drive.
Now you’ve successfully installed OpenCore, the required drivers, kexts and config.plist and the USB Flash drive is ready to boot off your computer.
UEFI Settings
  • Set Optimized Defaults.
  • Set X.M.P. Memory Profile to Profile 1.
  • Set Fast Boot to Disabled.
  • Set Windows 8/10 Features to Other OS.
  • Set Initial Display Output to IGFX.
  • Set Intel Platform Trust Technology (PTT) to Disabled.
  • Set Network Stack to Disabled.
  • Set XHCI Hand-Off to Enabled.
  • Set SATA Mode to AHCI.
  • Set VT-d option to Disabled.
  • Set Internal Graphics to Auto.
  • Save & Exit Setup.
Installation
Turn on your system.
6. Repeat step no. 5.
NameMacintosh HD
FormatAPFS
SchemeGUID Partition Map
12. Close Disk Utility.
This will take couple of minutes and will restart at "Less than a minute is remaining". Upon completion, the system will automatically restart. The System will restart to complete the installation. Here it ends the first phase of the installation.
Post Installation
Now, configuring the Post Installation. There is not much to do for the postinstallation except configuring Thunderbolt 4 Hotplug and the boot from system drive. Everything rest is fully functional.
To activate Thunderbolt 4, follow the steps from the guide linked below.
Boot from System Drive
3. Open your EFI Partition of your Hard Drive.
6. Copy the EFI folder from your macOS Bootable USB to your EFI Partition of your Hard Drive.
By using this method, you’ll be easily able to install OpenCore Boot loader on your System Drive.
  • Love
Reactions: philenn and utilman
Hi. I followed this guide, step by step, but I only got a black screen with the text "OC: Configuration requires vault, but no vault provided!"
oc vault.jpeg My hardware is:Motherboard: MSI MEG Z590 ACE
Processor: Intel Core i9 -10900
Graphics: Gigabyte AMD RX570
RAM: XPG GAMMIX DIO AX4U2666316G18-SBG DDR4 2666 16GB (2 modules)
RAM: ADATA AD4U2133316G15-S DDR4 2133 16GB (2 modules)
SSD: SAMSUNG NVME
¿What is wrong in my setup?
View attachment 3299My hardware is:Motherboard: MSI MEG Z590 ACE
SSD: SAMSUNG NVME
You have vault enabled. Disable File Vault settings in your config.plist and you should be good to go.
Thank You. I went to "Misc -> Security" and set "Vault" to "Optional", rebooted and it displayed the following mesage:
"OC: Driver HFSPlus.efi at 0 Cannot be found! Halting on critical error."
I guess it has to do with the UEFI driver, so I went to "UEFI -> Drivers", there I renamed "HfsPlus.efi" to "#HfsPlus.efi" (there where another items with the "#" prefix, so I guess it is used to ignore them) and moved down. Since I was already there, I used the "Scan/browse" button to add all the "*.efi" files in the "drivers" folder ("OpenRuntime.efi", "OpenHfsPlus.efi", "AudioDXE.efi", "OpenCanopy.efi", in that order).
Rebooted and Now, it says:
OCB: System has no boot entries
OC: Failed to show boot menu!
Halting on crittical error
So... I'm stuck again.
I Attach my current config.plist file and a picture of the last error screen.
Sorry, I'm new on this forum and I still don't know how to work with files on it, so I copy/paste'd the code.
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
    <key>#WARNING - 1</key>
    <string>This is just a sample. Do NOT try loading it.</string>
    <key>#WARNING - 2</key>
    <string>Ensure you understand EVERY field before booting.</string>
    <key>#WARNING - 3</key>
    <string>In most cases recommended to use Sample.plist</string>
    <key>#WARNING - 4</key>
    <string>Use SampleCustom.plist only for special cases.</string>
    <key>ACPI</key>
    <dict>
        <key>Add</key>
        <array>
            <dict>
                <key>Comment</key>
                <string>My custom DSDT</string>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>DSDT.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <string>My custom SSDT</string>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-1.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <string>Read the comment in dsl sample</string>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-ALS0.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-AWAC-DISABLE.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <true/>
                <key>Path</key>
                <string>SSDT-AWAC.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-BRG0.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <key>Path</key>
                <string>SSDT-EC-USBX.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-EC.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-EHCx-DISABLE.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-IMEI.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <key>Path</key>
                <string>SSDT-PLUG.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-PMC.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-PNLF.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-PNLFCFL.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-RTC0-RANGE.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-RTC0.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-SBUS-MCHC.aml</string>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Path</key>
                <string>SSDT-UNC.aml</string>
            </dict>
        </array>
        <key>Delete</key>
        <array>
            <dict>
                <key>All</key>
                <false/>
                <key>Comment</key>
                <string>Delete CpuPm</string>
                <key>Enabled</key>
                <false/>
                <key>OemTableId</key>
                <data>Q3B1UG0AAAA=</data>
                <key>TableLength</key>
                <integer>0</integer>
                <key>TableSignature</key>
                <data>U1NEVA==</data>
            </dict>
            <dict>
                <key>All</key>
                <false/>
                <key>Comment</key>
                <string>Delete Cpu0Ist</string>
                <key>Enabled</key>
                <false/>
                <data>Q3B1MElzdAA=</data>
            </dict>
        </array>
        <key>Patch</key>
        <array>
            <dict>
                <key>Base</key>
                <string></string>
                <key>BaseSkip</key>
                <key>Comment</key>
                <string>Replace one byte sequence with another</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>ESIzRA==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <data></data>
                <key>Replace</key>
                <data>RDMiEQ==</data>
                <key>ReplaceMask</key>
                <data></data>
                <key>Skip</key>
                <data></data>
            </dict>
            <dict>
                <key>Base</key>
                <string>\_SB.PCI0.LPCB.HPET</string>
                <key>BaseSkip</key>
                <key>Comment</key>
                <string>HPET _CRS to XCRS</string>
                <key>Count</key>
                <integer>1</integer>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>X0NSUw==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <data></data>
                <key>Replace</key>
                <data>WENSUw==</data>
                <data></data>
                <key>Skip</key>
                <data></data>
            </dict>
            <dict>
                <key>Base</key>
                <string></string>
                <key>BaseSkip</key>
                <key>Comment</key>
                <string>Rename PEGP to GFX0 (Graphics)</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>UEVHUA==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <data></data>
                <key>Replace</key>
                <data>R0ZYMA==</data>
                <data></data>
                <key>Skip</key>
                <data>RFNEVA==</data>
            </dict>
            <dict>
                <key>Base</key>
                <string></string>
                <key>BaseSkip</key>
                <key>Comment</key>
                <string>Rename HECI to IMEI (PAVP)</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>SEVDSQ==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <data></data>
                <key>Replace</key>
                <data>SU1FSQ==</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Base</key>
                <string></string>
                <key>BaseSkip</key>
                <key>Comment</key>
                <string>Rename MEI to IMEI (PAVP)</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>TUVJXw==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <data></data>
                <key>Replace</key>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Base</key>
                <string></string>
                <key>BaseSkip</key>
                <key>Comment</key>
                <string>Rename HDAS to HDEF (Audio)</string>
                <key>Count</key>
                <key>Enabled</key>
                <true/>
                <key>Find</key>
                <data>SERBUw==</data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <data></data>
                <key>Replace</key>
                <data>SERFRg==</data>
                <data></data>
                <key>Skip</key>
            </dict>
        </array>
        <key>Quirks</key>
        <dict>
            <key>FadtEnableReset</key>
            <false/>
            <key>NormalizeHeaders</key>
            <false/>
            <key>RebaseRegions</key>
            <false/>
            <key>ResetHwSig</key>
            <false/>
            <key>ResetLogoStatus</key>
            <true/>
        </dict>
    </dict>
    <key>Booter</key>
    <dict>
        <key>MmioWhitelist</key>
        <array>
            <dict>
                <key>Address</key>
                <integer>4275159040</integer>
                <key>Comment</key>
                <string>Haswell: SB_RCBA is a 0x4 page memory region, containing SPI_BASE at 0x3800 (SPI_BASE_ADDRESS)</string>
                <key>Enabled</key>
                <false/>
            </dict>
            <dict>
                <key>Address</key>
                <integer>4278190080</integer>
                <key>Comment</key>
                <string>Generic: PCI root is a 0x1000 page memory region used by some types of firmware</string>
                <key>Enabled</key>
                <false/>
            </dict>
        </array>
        <key>Patch</key>
        <array>
            <dict>
                <key>Arch</key>
                <string>Any</string>
                <key>Comment</key>
                <string>macOS to hacOS</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>bWFjT1M=</data>
                <key>Identifier</key>
                <string>Apple</string>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <key>Replace</key>
                <data>aGFjT1M=</data>
                <data></data>
                <key>Skip</key>
            </dict>
        </array>
        <key>Quirks</key>
        <dict>
            <key>AllowRelocationBlock</key>
            <false/>
            <key>AvoidRuntimeDefrag</key>
            <true/>
            <key>DevirtualiseMmio</key>
            <true/>
            <key>DisableSingleUser</key>
            <false/>
            <key>DisableVariableWrite</key>
            <false/>
            <key>DiscardHibernateMap</key>
            <false/>
            <key>EnableSafeModeSlide</key>
            <true/>
            <key>EnableWriteUnprotector</key>
            <false/>
            <key>ForceBooterSignature</key>
            <false/>
            <key>ForceExitBootServices</key>
            <false/>
            <key>ProtectMemoryRegions</key>
            <false/>
            <key>ProtectSecureBoot</key>
            <false/>
            <key>ProtectUefiServices</key>
            <false/>
            <key>ProvideCustomSlide</key>
            <true/>
            <key>ProvideMaxSlide</key>
            <key>RebuildAppleMemoryMap</key>
            <true/>
            <key>SetupVirtualMap</key>
            <false/>
            <key>SignalAppleOS</key>
            <false/>
            <key>SyncRuntimePermissions</key>
            <true/>
        </dict>
    </dict>
    <key>DeviceProperties</key>
    <dict>
        <key>Add</key>
        <dict>
            <key>PciRoot(0x0)/Pci(0x1b,0x2)/Pci(0x0,0x0)</key>
            <dict>
                <key>device-id</key>
                <data>8hUAAA==</data>
            </dict>
        </dict>
        <key>Delete</key>
        <dict/>
    </dict>
    <key>Kernel</key>
    <dict>
        <key>Add</key>
        <array>
            <dict>
                <key>Arch</key>
                <string>x86_64</string>
                <key>BundlePath</key>
                <string>Lilu.kext</string>
                <key>Comment</key>
                <string>Patch engine</string>
                <key>Enabled</key>
                <true/>
                <key>ExecutablePath</key>
                <string>Contents/MacOS/Lilu</string>
                <key>MaxKernel</key>
                <string></string>
                <key>MinKernel</key>
                <string>10.0.0</string>
                <key>PlistPath</key>
                <string>Contents/Info.plist</string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>VirtualSMC.kext</string>
                <key>Comment</key>
                <string>SMC emulator</string>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/VirtualSMC</string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>WhateverGreen.kext</string>
                <key>Comment</key>
                <string>Video patches</string>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/WhateverGreen</string>
                <string></string>
                <string>12.0.0</string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>AppleALC.kext</string>
                <key>Comment</key>
                <string>Audio patches</string>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/AppleALC</string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>USBInjectAll.kext</string>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/USBInjectAll</string>
                <string></string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>XHCI-unsupported.kext</string>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <true/>
                <string></string>
                <string></string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>FakePCIID.kext</string>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/FakePCIID</string>
                <string></string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>FakePCIID_Intel_I225-V.kext</string>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <true/>
                <string></string>
                <string></string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>NVMeFix.kext</string>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/NVMeFix</string>
                <string></string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>IntelMausi.kext</string>
                <key>Comment</key>
                <string>Intel Ethernet LAN</string>
                <key>Enabled</key>
                <false/>
                <string>Contents/MacOS/IntelMausi</string>
                <string></string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>Legacy_USB3.kext</string>
                <key>Comment</key>
                <string>XHC ports configuration</string>
                <key>Enabled</key>
                <false/>
                <string></string>
                <string></string>
                <string>15.0.0</string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>AppleMCEReporterDisabler.kext</string>
                <key>Comment</key>
                <string>AppleMCEReporter disabler</string>
                <key>Enabled</key>
                <false/>
                <string></string>
                <string></string>
                <string>19.0.0</string>
            </dict>
        </array>
        <key>Block</key>
        <array>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <false/>
                <string>com.apple.driver.AppleTyMCEDriver</string>
                <string></string>
                <string></string>
            </dict>
        </array>
        <key>Emulate</key>
        <dict>
            <key>Cpuid1Data</key>
            <data></data>
            <key>Cpuid1Mask</key>
            <data></data>
            <key>DummyPowerManagement</key>
            <false/>
            <string></string>
            <string></string>
        </dict>
        <key>Force</key>
        <array>
            <dict>
                <key>Arch</key>
                <string>System/Library/Extensions/IONetworkingFamily.kext</string>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <false/>
                <string>Contents/MacOS/IONetworkingFamily</string>
                <string>com.apple.iokit.IONetworkingFamily</string>
                <string>13.99.99</string>
                <string></string>
            </dict>
        </array>
        <key>Patch</key>
        <array>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string>__ZN8AppleRTC18setupDateTimeAlarmEPK11RTCDateTime</string>
                <key>Comment</key>
                <string>Disable RTC wake scheduling</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data></data>
                <string>com.apple.driver.AppleRTC</string>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <key>Replace</key>
                <data>ww==</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string>_AcpiOsVprintf</string>
                <key>Comment</key>
                <string>Disable ACPI logging</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data></data>
                <string>com.apple.driver.AppleACPIPlatform</string>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string>18.5.0</string>
                <key>Replace</key>
                <data>ww==</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string>__ZN11BCM5701Enet14getAdapterInfoEv</string>
                <key>Comment</key>
                <string>Broadcom BCM57785 patch</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>6AAA//9miYMABQAA</data>
                <string>com.apple.iokit.AppleBCM5701Ethernet</string>
                <key>Limit</key>
                <key>Mask</key>
                <data>/wAA////////////</data>
                <string>19.9.9</string>
                <string></string>
                <key>Replace</key>
                <data>uLQWAABmiYMABQAA</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string>_panic</string>
                <key>Comment</key>
                <string>Send panic string to serial port</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data></data>
                <string>kernel</string>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>MfaKD4TJdQT/xrEKZrr9A+yoIHT7Zrr4A4jI7kj/x4X2dN/r/g==</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string>_kernel_debug_string_early</string>
                <key>Comment</key>
                <string>Send early prints to serial port</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data></data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>MfaKD4TJdQT/xrEKZrr9A+yoIHT7Zrr4A4jI7kj/x4X2dN/D</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <string>_vstart</string>
                <key>Comment</key>
                <string>Print K and dead loop</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data></data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>sUtmuv0D7KggdPtmuvgDiMjusQpmuv0D7KggdPtmuvgDiMju6/4=</data>
                <data></data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <string>Early reboot</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data></data>
                <key>Limit</key>
                <key>Mask</key>
                <data></data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>McCwBrr5DAAA7uv+</data>
                <data></data>
                <key>Skip</key>
            </dict>
        </array>
        <key>Quirks</key>
        <dict>
            <key>AppleCpuPmCfgLock</key>
            <true/>
            <key>AppleXcpmCfgLock</key>
            <true/>
            <key>AppleXcpmExtraMsrs</key>
            <false/>
            <key>AppleXcpmForceBoost</key>
            <false/>
            <key>CustomSMBIOSGuid</key>
            <false/>
            <key>DisableIoMapper</key>
            <true/>
            <key>DisableLinkeditJettison</key>
            <true/>
            <key>DisableRtcChecksum</key>
            <false/>
            <key>ExtendBTFeatureFlags</key>
            <false/>
            <key>ExternalDiskIcons</key>
            <false/>
            <key>ForceSecureBootScheme</key>
            <false/>
            <key>IncreasePciBarSize</key>
            <false/>
            <key>LapicKernelPanic</key>
            <false/>
            <key>LegacyCommpage</key>
            <false/>
            <key>PanicNoKextDump</key>
            <true/>
            <key>PowerTimeoutKernelPanic</key>
            <true/>
            <key>SetApfsTrimTimeout</key>
            <integer>-1</integer>
            <key>ThirdPartyDrives</key>
            <false/>
            <key>XhciPortLimit</key>
            <true/>
        </dict>
        <key>Scheme</key>
        <dict>
            <key>FuzzyMatch</key>
            <true/>
            <key>KernelArch</key>
            <string>Auto</string>
            <key>KernelCache</key>
        </dict>
    </dict>
    <key>Misc</key>
    <dict>
        <key>BlessOverride</key>
        <array/>
        <key>Boot</key>
        <dict>
            <key>ConsoleAttributes</key>
            <key>HibernateMode</key>
            <string>None</string>
            <key>HideAuxiliary</key>
            <false/>
            <key>LauncherOption</key>
            <string>Disabled</string>
            <key>LauncherPath</key>
            <string>Default</string>
            <key>PickerAttributes</key>
            <integer>17</integer>
            <key>PickerAudioAssist</key>
            <false/>
            <key>PickerMode</key>
            <string>Builtin</string>
            <key>PickerVariant</key>
            <key>PollAppleHotKeys</key>
            <false/>
            <key>ShowPicker</key>
            <true/>
            <key>TakeoffDelay</key>
            <key>Timeout</key>
            <integer>5</integer>
        </dict>
        <key>Debug</key>
        <dict>
            <key>AppleDebug</key>
            <false/>
            <key>ApplePanic</key>
            <false/>
            <key>DisableWatchDog</key>
            <false/>
            <key>DisplayDelay</key>
            <key>DisplayLevel</key>
            <integer>2147483650</integer>
            <key>SerialInit</key>
            <false/>
            <key>SysReport</key>
            <false/>
            <key>Target</key>
            <integer>3</integer>
        </dict>
        <key>Entries</key>
        <array>
            <dict>
                <key>Arguments</key>
                <string></string>
                <key>Auxiliary</key>
                <false/>
                <key>Comment</key>
                <string>Not signed for security reasons</string>
                <key>Enabled</key>
                <false/>
                <key>Name</key>
                <string>CustomOS</string>
                <key>Path</key>
                <string>PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/NVMe(0x1,11-22-33-44-55-66-77-88)/HD(1,GPT,00000000-0000-0000-0000-000000000000,0x800,0x64000)/\EFI\BOOT\BOOTX64.EFI</string>
                <key>TextMode</key>
                <false/>
            </dict>
        </array>
        <key>Security</key>
        <dict>
            <key>AllowNvramReset</key>
            <false/>
            <key>AllowSetDefault</key>
            <false/>
            <key>ApECID</key>
            <key>AuthRestart</key>
            <false/>
            <key>BlacklistAppleUpdate</key>
            <true/>
            <key>DmgLoading</key>
            <string>Signed</string>
            <key>EnablePassword</key>
            <false/>
            <key>ExposeSensitiveData</key>
            <integer>6</integer>
            <key>HaltLevel</key>
            <integer>2147483648</integer>
            <key>PasswordHash</key>
            <data></data>
            <key>PasswordSalt</key>
            <data></data>
            <key>ScanPolicy</key>
            <integer>17760515</integer>
            <key>SecureBootModel</key>
            <key>Vault</key>
            <string>Optional</string>
        </dict>
        <key>Tools</key>
        <array>
            <dict>
                <string></string>
                <false/>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Name</key>
                <string>UEFI Shell</string>
                <key>Path</key>
                <string>OpenShell.efi</string>
                <key>RealPath</key>
                <false/>
                <key>TextMode</key>
                <false/>
            </dict>
            <dict>
                <string></string>
                <false/>
                <key>Comment</key>
                <string>Memory testing utility</string>
                <key>Enabled</key>
                <false/>
                <key>Name</key>
                <string>memcheck</string>
                <key>Path</key>
                <string>memcheck/memcheck.efi</string>
                <key>RealPath</key>
                <false/>
                <key>TextMode</key>
                <false/>
            </dict>
            <dict>
                <string>Shutdown</string>
                <true/>
                <key>Comment</key>
                <string>Perform shutdown</string>
                <key>Enabled</key>
                <false/>
                <key>Name</key>
                <key>Path</key>
                <string>ResetSystem.efi</string>
                <key>RealPath</key>
                <false/>
                <key>TextMode</key>
                <false/>
            </dict>
        </array>
    </dict>
    <key>NVRAM</key>
    <dict>
        <key>Add</key>
        <dict>
            <key>4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14</key>
            <dict>
                <key>DefaultBackgroundColor</key>
                <data>AAAAAA==</data>
                <key>UIScale</key>
                <data>AQ==</data>
            </dict>
            <key>4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102</key>
            <dict>
                <key>rtc-blacklist</key>
                <data></data>
            </dict>
            <key>7C436110-AB2A-4BBB-A880-FE41995C9F82</key>
            <dict>
                <key>SystemAudioVolume</key>
                <data>Rg==</data>
                <key>boot-args</key>
                <string>-v debug=0x100 keepsyms=1 alcid=11</string>
                <key>csr-active-config</key>
                <key>prev-lang:kbd</key>
                <string>en-US:0</string>
                <key>run-efi-updater</key>
                <string>No</string>
            </dict>
        </dict>
        <key>Delete</key>
        <dict>
            <array>
                <string>UIScale</string>
                <string>DefaultBackgroundColor</string>
            </array>
            <array>
                <string>rtc-blacklist</string>
            </array>
            <array>
                <string>boot-args</string>
            </array>
        </dict>
        <key>LegacyEnable</key>
        <false/>
        <key>LegacyOverwrite</key>
        <false/>
        <key>LegacySchema</key>
        <dict>
            <array>
                <string>EFILoginHiDPI</string>
                <string>EFIBluetoothDelay</string>
                <string>LocationServicesEnabled</string>
                <string>SystemAudioVolume</string>
                <string>SystemAudioVolumeDB</string>
                <string>SystemAudioVolumeSaved</string>
                <string>bluetoothActiveControllerInfo</string>
                <string>bluetoothInternalControllerInfo</string>
                <string>flagstate</string>
                <string>fmm-computer-name</string>
                <string>fmm-mobileme-token-FMM</string>
                <string>fmm-mobileme-token-FMM-BridgeHasAccount</string>
                <string>nvda_drv</string>
                <string>prev-lang:kbd</string>
            </array>
            <key>8BE4DF61-93CA-11D2-AA0D-00E098032B8C</key>
            <array>
                <string>Boot0080</string>
                <string>Boot0081</string>
                <string>Boot0082</string>
                <string>BootNext</string>
                <string>BootOrder</string>
            </array>
        </dict>
        <key>WriteFlash</key>
        <true/>
    </dict>
    <key>PlatformInfo</key>
    <dict>
        <key>Automatic</key>
        <true/>
        <key>CustomMemory</key>
        <false/>
        <key>DataHub</key>
        <dict>
            <key>ARTFrequency</key>
            <key>BoardProduct</key>
            <string>Mac-AF89B6D9451A490B</string>
            <key>BoardRevision</key>
            <data>AQ==</data>
            <key>DevicePathsSupported</key>
            <key>FSBFrequency</key>
            <key>InitialTSC</key>
            <key>PlatformName</key>
            <string></string>
            <key>SmcBranch</key>
            <data></data>
            <key>SmcPlatform</key>
            <data>ajE4NWYAAAA=</data>
            <key>SmcRevision</key>
            <data></data>
            <key>StartupPowerEvents</key>
            <key>SystemProductName</key>
            <string>iMac20,2</string>
            <key>SystemSerialNumber</key>
            <string>C02CG0E1046M</string>
            <key>SystemUUID</key>
            <string>29DB4A56-688A-49B0-A1FC-145A1A7661D3</string>
        </dict>
        <key>Generic</key>
        <dict>
            <key>AdviseWindows</key>
            <false/>
            <key>MaxBIOSVersion</key>
            <false/>
            <key>MLB</key>
            <string>C02012108GU0000UE</string>
            <key>ProcessorType</key>
            <key>ROM</key>
            <data>ESIzRFVm</data>
            <key>SpoofVendor</key>
            <true/>
            <key>SystemMemoryStatus</key>
        </dict>
        <key>SMBIOS</key>
        <dict>
            <key>BIOSReleaseDate</key>
            <string>01/06/2021</string>
            <key>BIOSVendor</key>
            <string></string>
            <key>BIOSVersion</key>
            <string>1554.80.3.0.0</string>
            <key>BoardAssetTag</key>
            <string>Base Board Asset Tag</string>
            <key>BoardLocationInChassis</key>
            <string>Part Component</string>
            <key>BoardManufacturer</key>
            <string></string>
            <key>BoardSerialNumber</key>
            <key>BoardType</key>
            <integer>10</integer>
            <key>BoardVersion</key>
            <key>ChassisAssetTag</key>
            <string>Asset Tag#</string>
            <key>ChassisManufacturer</key>
            <string></string>
            <key>ChassisSerialNumber</key>
            <key>ChassisType</key>
            <integer>13</integer>
            <key>ChassisVersion</key>
            <key>FirmwareFeatures</key>
            <data>dvWP/QAAAAA=</data>
            <key>FirmwareFeaturesMask</key>
            <data>f//f/wAAAAA=</data>
            <key>PlatformFeature</key>
            <integer>32</integer>
            <integer>4105</integer>
            <key>SmcVersion</key>
            <data></data>
            <key>SystemFamily</key>
            <string>iMac</string>
            <key>SystemManufacturer</key>
            <string></string>
            <key>SystemSKUNumber</key>
            <string>System SKU#</string>
            <key>SystemVersion</key>
            <string>1.0</string>
        </dict>
        <key>UpdateDataHub</key>
        <true/>
        <key>UpdateNVRAM</key>
        <true/>
        <key>UpdateSMBIOS</key>
        <true/>
        <key>UpdateSMBIOSMode</key>
        <string>Create</string>
        <key>UseRawUuidEncoding</key>
        <false/>
    </dict>
    <key>UEFI</key>
    <dict>
        <key>APFS</key>
        <dict>
            <key>EnableJumpstart</key>
            <true/>
            <key>GlobalConnect</key>
            <false/>
            <key>HideVerbose</key>
            <true/>
            <key>JumpstartHotPlug</key>
            <false/>
            <key>MinDate</key>
            <key>MinVersion</key>
        </dict>
        <key>AppleInput</key>
        <dict>
            <key>AppleEvent</key>
            <key>CustomDelays</key>
            <key>KeyInitialDelay</key>
            <key>KeySubsequentDelay</key>
            <key>PointerSpeedDiv</key>
            <key>PointerSpeedMul</key>
        </dict>
        <key>Audio</key>
        <dict>
            <key>AudioCodec</key>
            <key>AudioDevice</key>
            <string>PciRoot(0x0)/Pci(0x1b,0x0)</string>
            <key>AudioOut</key>
            <key>AudioSupport</key>
            <false/>
            <key>MinimumVolume</key>
            <integer>20</integer>
            <key>PlayChime</key>
            <key>ResetTrafficClass</key>
            <false/>
            <key>SetupDelay</key>
            <key>VolumeAmplifier</key>
        </dict>
        <key>ConnectDrivers</key>
        <true/>
        <key>Drivers</key>
        <array>
            <string>OpenRuntime.efi</string>
            <string>OpenHfsPlus.efi</string>
            <string>AudioDxe.efi</string>
            <string>OpenCanopy.efi</string>
            <string>#HfsPlus.efi</string>
            <string>#OpenCanopy.efi</string>
            <string>#AudioDxe.efi</string>
            <string>#OpenPartitionDxe.efi</string>
            <string>#OpenUsbKbDxe.efi</string>
            <string>#UsbMouseDxe.efi</string>
            <string>#Ps2KeyboardDxe.efi</string>
            <string>#Ps2MouseDxe.efi</string>
            <string>#HiiDatabase.efi</string>
            <string>#NvmExpressDxe.efi</string>
            <string>#XhciDxe.efi</string>
            <string>#ExFatDxe.efi</string>
            <string>#CrScreenshotDxe.efi</string>
        </array>
        <key>Input</key>
        <dict>
            <key>KeyFiltering</key>
            <false/>
            <key>KeyForgetThreshold</key>
            <key>KeySupport</key>
            <true/>
            <key>KeySupportMode</key>
            <key>KeySwap</key>
            <false/>
            <key>PointerSupport</key>
            <false/>
            <key>PointerSupportMode</key>
            <string>ASUS</string>
            <key>TimerResolution</key>
            <integer>50000</integer>
        </dict>
        <key>Output</key>
        <dict>
            <key>ClearScreenOnModeSwitch</key>
            <false/>
            <key>ConsoleMode</key>
            <string></string>
            <key>DirectGopRendering</key>
            <false/>
            <key>ForceResolution</key>
            <false/>
            <key>GopPassThrough</key>
            <false/>
            <key>IgnoreTextInGraphics</key>
            <false/>
            <key>ProvideConsoleGop</key>
            <true/>
            <key>ReconnectOnResChange</key>
            <false/>
            <key>ReplaceTabWithSpace</key>
            <false/>
            <key>Resolution</key>
            <string>Max</string>
            <key>SanitiseClearScreen</key>
            <false/>
            <key>TextRenderer</key>
            <string>BuiltinGraphics</string>
            <key>UgaPassThrough</key>
            <false/>
        </dict>
        <key>ProtocolOverrides</key>
        <dict>
            <key>AppleAudio</key>
            <false/>
            <key>AppleBootPolicy</key>
            <false/>
            <key>AppleDebugLog</key>
            <false/>
            <key>AppleFramebufferInfo</key>
            <false/>
            <key>AppleImageConversion</key>
            <false/>
            <key>AppleImg4Verification</key>
            <false/>
            <key>AppleKeyMap</key>
            <false/>
            <key>AppleRtcRam</key>
            <false/>
            <key>AppleSecureBoot</key>
            <false/>
            <key>AppleSmcIo</key>
            <false/>
            <key>AppleUserInterfaceTheme</key>
            <false/>
            <key>DataHub</key>
            <false/>
            <false/>
            <key>FirmwareVolume</key>
            <true/>
            <key>HashServices</key>
            <false/>
            <key>OSInfo</key>
            <false/>
            <key>UnicodeCollation</key>
            <false/>
        </dict>
        <key>Quirks</key>
        <dict>
            <key>ActivateHpetSupport</key>
            <false/>
            <key>DisableSecurityPolicy</key>
            <false/>
            <key>ExitBootServicesDelay</key>
            <key>IgnoreInvalidFlexRatio</key>
            <false/>
            <key>ReleaseUsbOwnership</key>
            <false/>
            <key>RequestBootVarRouting</key>
            <true/>
            <key>TscSyncTimeout</key>
            <key>UnblockFsConnect</key>
            <false/>
        </dict>
        <key>ReservedMemory</key>
        <array>
            <dict>
                <key>Address</key>
                <integer>268435456</integer>
                <key>Comment</key>
                <string>HD3000: IGPU memory corruption errata</string>
                <key>Enabled</key>
                <false/>
                <key>Size</key>
                <key>Type</key>
                <string>Reserved</string>
            </dict>
            <dict>
                <key>Address</key>
                <integer>569344</integer>
                <key>Comment</key>
                <string>Fix black screen on wake from hibernation for Lenovo Thinkpad T490</string>
                <key>Enabled</key>
                <false/>
                <key>Size</key>
                <integer>4096</integer>
                <key>Type</key>
                <string>RuntimeCode</string>
            </dict>
        </array>
    </dict>
</dict>
</plist>
Also, I must say, I can't find in the BIOS the following options
and, I can't Enable XMP1
(Quick question. May I continue posting here my doubts or must I create a new thread?)
Thanks in advance
That's normal. Your configuration is still wrong.
What you don't have in BIOS, you can simply ignore it.
Thanks in advance
You can continue with this thread.
Attach your EFI to check.
Thank you, Attached comes the full EFI folder.
Here are following issues.
- Arch is defined in the kernel section. It must be set to auto.
- MinKernel is defined in the kernel section. It must not be defined, unless needed.
You should consider starting fresh to avoid issues.
Thank you very much for this post / Tutourial. Very helpful.
hi @EliteMacx86 !
Thank you for this post. I am looking to build exactly this system in a TU150 chassis. I was wondering if any non-F CPU (like 10700k) could be used with this setup and onboard graphics (intel UHD 630), since graphics cards are very hard to buy right now.
I have an eGPU for use with Windows 10 (to play games), I will run both Windows 10 and macOS on different SSDs. Later I will get some AMD GPU that will work natively in macOS, but for now I would need to use onboard HDMI and DisplayPort.
Also: is the new Maple Ridge controller USB2.0 and USB3.0 connected as part of the PCH? Or separate? Which ports do you have enabled successfully for the system? (wondering how this motherboard works with the 15 port limit)
Did you find Big Sur, Catalina, or Mojave to work best with your build?
ilikeeatingpeeandpoo
