Wake after sleep when connecting iPhone to Titan Ridge THB 3 card
obus
WS C422 PRO/SE
Xeon W-2175 14 Cores
Vega 64
10.13.x
  1. iMac Pro
Hi guys
I'm a newbie on this forum and I have a problem with my TitanRidge Thunderbolt 3 cards. I'am running OpenCore 0.6.7 with two Gigabyte Titan Ridge thunderbolt 3 card installed. Everything is working and running smoothly with working sleep. As soon as I plug in my iPhone on any of my four Titan Ridge ports sleep stops working and I got immediate wake. I have both cards connected to an internal NZXT USB-2-hub because otherwise my phone isn't showing up in About this Mac ----> System Report ----> USB and neither in my Music app. My two cards is flashed with custom firmware (DESIGNARE-Z390-NVM33-Elias64Fr.bin) and with a jumper for pin 3 and 5 for power and Hot Swap capability.
Any ideas?
Hi guys
Any ideas?
No PR files attached.
Ok.
Here we go!
Ok.
Here we go!
For now, do the following changes.
- Disable SSDT-GFX0
- Switch to VirtualSMC.kext
- Disable AsMedia.kext
- Disable ThunderboltReset.kext
- Disable Sensors kexts.
- Enable FuzzyMatch
- Enable AppleCPUPmCfgLock
- Enable AppleXcpmCfgLock
- DisableIoMapper
- Disable TbtForcePower.efi
Reply with new PR files.
Ok.
Sleep is working flawlessly as before without my iPhone connected. As soon as I connect it to any of the four THB 3 ports on my Titan Ridge cards sleep stop working with instant reboot. If I connect the phone to my AsMedia USB-C 3.1 port in front or rear port sleep is working.
Just for your information. I need the AsMedia.kext because occasionally the ports on the AsMedia controller is not recognized after reboot. FakeSMC and sensors is working well in my setup and I need all of them for iStat Menus.app.
It works with VirtualSMC too.
Disable Rename XHCI to XHC (USB) and then check.
Disable USBMap and use USBInjectAll
Do the above changes and reset NVRAM twice. Test Sleep/Wake and reply with new PR files.
Firstly I will thank you for your efforts, I really appreciate that.
Secondly I didn't know that the ACPI sensors was working with VirtualSMC. That is good to know.
I did what you advice me to do. I enabled USBInjectAll but not the XhciPortLimit quirk in OC.
With this setup the rig was sleeping only whitout the iPhone plugged in to any of the THB 3 ports.
Attached new PR_Files.
Do you keep the iPhone connected and then put the system to sleep?
Yes. It's only the phone how is triggering this. If I connect an external disk to the same port sleep is working as it should.
Problems solved.
I compiled two new SSDT (Casey, TBTGA390) for my two Titan Ridge cards with updated Drom:s and Bus Id:s. Now sleep is working flawlessly regardless on which port I plug in my phone. Kudos to @scottkendall and @caseySJ for using SSDT-TR.aml/TBTGA390, perfect for my firmware GC-TITAN-RIDGE-NVM23-Elias64Fr.bin
Thank's anyway for your support
PS. Enabled internet sharing on iPhone could be a culprit. If anybody has the same problem as me first test to disable internet sharing. This could solve immediate wake after sleep on your hack.
fernandorech
