Become a Premium Member for $25/year with no ads to improve your community experience.
Problem Reporting Files. Check the FAQ section for more informationI will, what are PR files ?
Please check the details once again. The post was updated when i was replying to your previous message.So:
Details:
Screen shots:
- Gigabyte Titan Ridge 2.0 with NVM50 Modded Firmware by CaseySJ
- macOS 10.14.6
- Copy of IOReg -> attached
- Kextcache output
Files:
- Hackintool>PCIe
- System Report>PCI
- For Clover, compress EFI/Clover, exclude the themes folder.
- For OpenCore, compress EFI/OC.
I used the 'RunMe App' so normally everything should be in it...
updated the post abovePlease check the details once again. The post was updated when i was replying to your previous message.
If i'm understanding it correct, the issue you have is you're not able to load up your TB Device. The TB device shows in IOReg but it doesn't loads. Is that correct?So:
Details:
Screen shots:
- Thunderbolt Chip and Family:
Titan Ridge - JHL7540- Thunderbolt Vendor/Manufacturer:
Gigabyte GC-Titan Ridge 2.0- Thunderbolt Type (Onboard or AIC):
AIC- Thunderbolt AIC PCI Slot Location:
PCIEX8 (2nd PCIe Slot if you don't count the PCIx1 slots, otherwise it's the 5th slot)- Motherboard Model:
Gigabyte Z77X - UD5H f16 mod 11 BIOS- CPU Model:
Intel i7-3770K (Stock)- macOS version:
macOS 10.14.6- Copy of IOReg
- Kextcache output
Files:
- Hackintool>PCIe
- System Report>PCI
That's very normal. In both the cases, the TB device is being recognized and is not loading. It's a very common issue. Provide the missing details.So, when using the SSDT to get proper ThunderBolt injection into the system, my Avid HDX Card is recognized in the system, but the driver isn't loaded / doesn't recognize the card.
When not using the SSDT the card is been seen by the driver
I attached 2 screenshots, one with SSDT injected, one with no injection
My bad. Looks like i missed the TB Device name. In your PR files, there is no SSDT for TB. Check once again.TB Device name of what ?
It's a Avid HDX PCIe 2.0 x4 Card in an Sonnet Echo III
This one is special made for HDX Cards.
