[SOLVED] AppleACPIPlatform Kernel Panic while running macOS Big Sur installer on X79 Motherboard
jr3k
Asus P9X79 Pro
Intel Core i7-3930K
NVIDIA GeForce GTX 680
10.14.x
I am trying to upgrade my Catalina 10.15.7 to Big Sur, or even get a fresh install.
My system works fine with opencore 0.6.3. Everything seems to be working fine, audio, ethernet, video, etc.
My problem happens when I try the Install macOS Big Sur option in the USB. After a little bit it stops at the error shown below.
If anyone could have any ideas on how to solve this I really appreciate.
I am attaching a photo of the error and my EFI folder
Thanks
Thanks
There's a KP due to AppleACPIPlatform.
Install SSDT-EC0 or add a rename in your config.plist.
Thanks for replying, but I have added a rename in my config and the error seems the same
  • config.plist.zip
    config.plist.zip
Fill out the details in your profile.
The KP is due to the PR00 in your DSDT. You need to remove the DSDT and it should boot fine.
I am not sure I know how to do that. Thanks anyway.
Just uncheck the "DSDT" in your config.plist in the ACPI section.
Thanks for your patience.
This is what I have done:
- uncked DSDT
- on reboot, reset nvram
- select the Big sur install
The machine will reboot on its own.
- uncked DSDT
Probably, there's a KP. You need to attach a picture like your first post.
Here it is ..seems the same
Add the following patch in your ACPI section under patch.
Name: UNC0 _HID to XHID
Find: 554E43 30085F48 4944
Replace: 554E43 30085848 4944
g.gott81
