I guess my main problem is that I haven't been able to identify the exact audio codec I have.
Well, i'll update this guide soon to identify the Audio Codec on Mac and Windows.
Your Audio Codec is "Conexant CX8200"
Some issues which are listed below.
ACPI is not patched. See the guide here:
The layout ID must be same in the Audio and the Device>Properties section.
Using a KabyLake Spoof for the KabyLake-R Graphics, when it's supported natively, isn't a good idea. Remove Intel GFX entry, uncheck Inject Intel checkbox and also remove the ig-platform-id.
You said "Any Audio Codec from the supported vendors". I have a VT1708S, are you sure that this codec can be patched?
aptop del vostro 3401 Processor : Intel Core i5 1035g1 - RAM: 8 GB DDR4 2666Mhz - IGPU: Intel UHD - Storage: intel 360 SSD 512gb - Ethernet: Realtek RTL8111 - Wifi: Realtek RTL8821 Wifi + Bluetooth - USB: Intel Chipset - Audio Codec: CIRRUS LOGIC CS42L63A (Cirrus Logic CS42L63A @ Intel Sunrise Point PCH)
https://drive.google.com/file/d/1OjQRiyTCN1aIgYFFaiEM6NSU82omz9P1/view?fbclid=IwAR1fUd8Oh-ageG0C_iLeFR99aiTAsioDPnkdINgBEsHMBXGy0x9TplGINSU
Can you help me ! no soun word
  • codec_dump.txt
    codec_dump.txt
  • CodecDump 2.zip
    CodecDump 2.zip
Incomplete PR files attached. For Laptops, ACPI patching is necessary.
See the updated guide below
help me Patch apple HDA i tried everything but the sound is not working , please help me ,. this is the audio info i got in linux
No need of this as this is more appropriate for old version of macOS.
giúp tôi Patch apple HDA tôi đã thử mọi cách nhưng âm thanh không hoạt động, xin hãy giúp tôi
Bộ giải mã: Cirrus Logic CS8409 / CS42L42
J.An
