How to Install Catalina on Hp15r014tx core i5-4210u intel 4400 8gb ram.
Hello, Please reply Sir.
Thanks for your help, Sir. I successfully installed the macOs Catalina .
Great.
I am unable check battery
usb 3.0 not working
No PR files attached.
sound not working
realtek ethernet
Find your Device ID and use the appropriate kext.
Hint: On Laptops, you need to also patch DSDT for Audio.
One more thing when I try to boot its show EFI file from my mac SSD. while other shows OS Boot Manager (UEFI) For Windows . I need this because I can only change boot sequence if it shows OS Boot Manager, bios setting doesn't detect the EFI SSD.
HP doesn't offers it. The only way is to merge it and use the Dual Boot parameters. Check Dual Boot guides.
Thanks for your help, Sir. I successfully installed the macOs Catalina . Can You please help me post installation . I am unable check battery ,usb 3.0 not working , sound not working ,realtek ethernet not working and other patches that are required post installation.
Can you please link me your working clover files, I have the same laptop and would like to try hackintosh on it.
Hi, I tried making opencore EFI for my HP 15r014tx but after the apple logo loading the installer is crashing with NSRangeexception error I have attached my EFI Files and logs please help me.
natsukiro
