Fix Asus Vivobook 15
Liux
Asus F515F Vivobook 15
i5 8625-u
Intel UHD 620
10.13.x
Hi!
I successfully installed Olarila Catalina in an Asus Vivobook 15.
I've just made some fix like:
-GPU
-Audio
-Backlight
Can you help me for this fixes?
-Battery Status
-Bluetooth (i know that can work, i use IntelBluetooth, but now doesn't work anymore, so i removed the kext)
-Keyboard and trackpad
PC Specs:
CPU : I5 8625u
GPU: UHD 620
Wifi: Intel 9560 (I've bought an usb wireless key that works with catalina on amazon)
Audio: Realtek 256
Here is my efi!
Hi!
-GPU
-Audio
-Backlight
-Battery Status
PC Specs:
CPU : I5 8625u
GPU: UHD 620
Audio: Realtek 256
Here is my efi!
Allow access to your file.
Thanks for the reply! :)
I totally forgot to allow access, try now!
natsukiro
