I read it and cannot find an answer to those questions so I asked you bro
if I missed something so show me what part of guide is about these?
The FAQ section already covers it. Use DPCI Manager to find your USB and related info.
so I found USB series but in the audio device section, there is no codec info
where can I find it? can I find it inside windows or should check it via ubuntu? is AppleHDA patching is needed before applying the layout ID patch? what about disabling discrete Nvidia graphics patch?
The basic guide:
If you want to patch AppleHDA, then follow the guide below
The basic guide:
Which one is better and you suggest it most?
The first one.
thanks in the insert layout ID for my codec it listed many layout IDs what should I enter in the Inject?
my codec is
Codec: Realtek ALC269VC
I tested it with layout ID 1 but it didn't work and didn't show anything in the output tab of sound in system preferences
isn't it a part of patching? I'm in the step of patching layout ID
Audio is another part. The original thread was about patching errors which has been fixed and the thread must be closed for other issue, a separate thread must be opened. :)
Write your reply...
Dzikon
