SMBIOS choice for Hp Probook 450 G6
mehmetyuksel
Hp Probook 450 G6
Core i7
intel uhd 620
10.13.x
Hi Dear Friends,
My System: HP 6MQ75EAQ ProBook 450 G6 i7-8565U 8GB
1TB+256GB SSD Intel UHD Graphics 620 +2gb MX130 Mac Os Catalina 10.5.3 + Windows 10 (Pro Edu)
which one should I choose.
Sincerely. Thanks.
Hi Dear Friends,
Sincerely. Thanks.
Hello and welcome to EliteMacx86.com
I think the best SMBIOS for your setup is the MacBookPro15,3 which is for a MacBookPro with an i7 CPU inside.
Reactions: mehmetyuksel
Hi Dear Friends,
Sincerely. Thanks.
Use MBP 14,1 which is as per the guide. Start here:
Isn't better to choose the closest SMBIOS to the CPU? I know that when you choose the SMBIOS based on the CPU generation you'll get better Power Management results.
It is. When it comes to Laptops, things changes a lot.
Frequency Vectors can be edited or copied from another SMBIOS, for new CPUs, it's not even required. :)
so which one should I choose? @EliteMacx86
Use MBP14,1. Check the guide here:
Following the guide will bring the maxed out performance.
Thanks...May Allah bless and protect us all from Covid
  • Love
raymondleung416
