- Mar 19, 2020
- Hp Probook 450 G6
- Core i7
- intel uhd 620
- 10.13.x
- Clover (UEFI)
Hello and welcome to EliteMacx86.comHi Dear Friends,
My System: HP 6MQ75EAQ ProBook 450 G6 i7-8565U 8GB
1TB+256GB SSD Intel UHD Graphics 620 +2gb MX130 Mac Os Catalina 10.5.3 + Windows 10 (Pro Edu)
which one should I choose.
Sincerely. Thanks.
Use MBP 14,1 which is as per the guide. Start here:Hi Dear Friends,
Sincerely. Thanks.
www.elitemacx86.com
Isn't better to choose the closest SMBIOS to the CPU? I know that when you choose the SMBIOS based on the CPU generation you'll get better Power Management results.Use MBP 14,1 which is as per the guide. Start here:
GUIDE - How to Boot macOS Installer on Laptops using Clover (UEFI/Legacy)
Booting macOS installer on laptops can be a challenge for the new users. This guide covers a complete step to boot the macOS installer on your Laptop using Clover bootloader. Those who are not using Clover, can update their configuration for clover and continue to use it. Clover is one of the...www.elitemacx86.com
It is. When it comes to Laptops, things changes a lot.Isn't better to choose the closest SMBIOS to the CPU?
Frequency Vectors can be edited or copied from another SMBIOS, for new CPUs, it's not even required.I know that when you choose the SMBIOS based on the CPU generation you'll get better Power Management results.
so which one should I choose? @EliteMacx86Isn't better to choose the closest SMBIOS to the CPU? I know that when you choose the SMBIOS based on the CPU generation you'll get better Power Management results.
Use MBP14,1. Check the guide here:so which one should I choose? @EliteMacx86
www.elitemacx86.com
Thanks...May Allah bless and protect us all from CovidUse MBP14,1. Check the guide here:
Following the guide will bring the maxed out performance.
You're welcome. Hopefully, it will be all sorted out soon.Thanks...May Allah bless and protect us all from Covid
had you able to update your macos to latest verThanks...May Allah bless and protect us all from Covid
