Black Internal screen when use HDMI port, problem with SSDT-PNLF
phoenix
Acer E5 575 - 32AB
i3-7100U
Intel HD Graphics 620
Hello, you guys! I'm got some problem with my Hackintosh laptop, detail below.
My laptop's information:
  • Model: Acer E5-575
  • CPU: Intel Core i3-7100U
  • IGPU: Intel HD Graphics 620
  • RAM: 4GBx1 + 8GBx1 => 12GB RAM Bus 2133
  • Wifi: Replaced with DW1820A.
  • Clover: Clover 5106
  • UEFI/LEGACY: UEFI
What's working/not working on my Hackintosh laptop?
  • All working except HDMI + Brightness (Must choose one of HDMI and Brightness)
  • The laptop will force reboot when plugged in the VGA cable (I really don't need VGA port, maybe don't care this)
With 3 version macOS(10.13, 10.14, 10.15), I got different problem below
* With macOS High Sierra (10.13.6):
I patched framebuffer with Intel HD 620, you can see in the "config.plist" I attached.
When I patch SSDT-PNLF into Clover/ACPI/patched:
I can modify the brightness with the slider and hotkeys, it's working without problem but when I plug HDMI cable into my laptop, the internal screen (laptop) is black and screen of HDMI is still working. (Only internal screen black), and when I try to plug HDMI cable out, Internal screen is still black and it doesn't recover again
Note with this method:
  • Black internal screen but backlight still working.
  • When I closed lid or sleep before plug HDMI cable, then wake the laptop up. I can plug in/plug out without black internal screen
When I remove SSDT-PNLF from Clover/ACPI/patched
I plug HDMI cable into my laptop, Internal screen and HDMI screen is working fine (No more black on internal screen).
But because without SSDT-PNLF hotpatch, I can't control my backlight brightness.
* With macOS Mojave/Catalina (10.14.x/10.15.x):
And with mojave&catalina all 3rd party application is so slow when open than default and system app. I take about 20s for open, (High Sierra 10.13.6 is open so fast, ~2,3 seconds) (If you know this problem, please help me)
I can adjust brightness or plug the HDMI cable in/out without problem. But the Internal screen is wrong colour or depth colours like this:
Note: The internal screen is wrong with colour even when I haven't plugged in the HDMI cable, it's default when booting hackintosh up success
____________
With 10.13 when I closed lid or sleep before plug HDMI cable, then wake the laptop up. I can plug in/plug out without black internal screen
With 10.14 & 10.15 when I closed lid or sleep, then wake the laptop up, the internal screen is normal, no more effect by wrong colours
Because EFI & ioreg so large, I'll upload with my driver file.
EFI => download EFI
ioReg => ioRegs copy
I'm using High Sierra 10.13.6, you can skip Mojave/Catalina problem if you don't have time!
Thanks for reading, hope you can help me!
  • UEFI/LEGACY: UEFI
____________
EFI => download EFI
Use Catalina and start here:
Reactions: phoenix
Sorry, but I can't use Mojave/Catalina because of that.
P/S: My config from https://github.com/RehabMan/OS-X-Clover-Laptop-Config and modified it for fix such as audio, USB port, sleep, ...
  • Haha
Reactions: phoenix
Well, it's your wish. Still based on High Sierra, your configuration is not proper. If you're willing to put efforts, you can have everything working on this forum. :)
Well, I'll backup High Sierra and try to install Catalina again with your guide again. If it gets "slow when open 3rd party app problem again", Can you help me solve it?
P/S: I confused with 2 configs from Rehabman.
config_HD615_620_630_640_650.plist
config_HD615_620_630_640_650_spoof.plist
Which config file will fit with my i3-7100U, Intel HD 620 laptop?
High Sierra is bit old. If you want to use 32-bit Apps, Mojave is the go. Yes, we're here to fix your issues.
Use "config_HD615_620_630_640_650.plist"
gopon_user
