[Solved] - DSDT - MacIASL does not allow me to apply the patch
Was this thread helpful?
  • Yes
    Votes: 0 0.0%
  • Partially
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
    0
Ye the brightness buttons does not work and that file returns 183 errors when compiled if you can compile it successfully then can you add the brightness button patch you suggested and share it with me so that I can put it in clover acpi patched
Thats probably clear enough
You already have the patch in the .DSL file. So just compile it. Better if you can attach a video. If you're unable to compile, what MaciASL version are you using?
I am using version 1.4 downloaded from sourceforge
I had attached a screenshot before and nothing to show in video I open file and click compile nothing more
Use the MaciASL from the guide i wrote.
If you say it matters then I will try
That fixed the errors now its time to apply the patch. :)
Edited:
Buttons are swapped but other than that I'm fine. Thanks for your help.
And excuse me but I have some questions
1- Can I use my dedicated GPU on my laptop
2- Can I share these information on my page(with giving credit)
3-How can I fix my HDMI? My laptop reboots when I connect HDMI?
Sure.
https://bitbucket.org/RehabMan/os-x-maciasl-patchmatic/downloads/
Yes, it's already mentioned in the guide.
Nice.
You mean the when you press Brightness UP, it decreases the Brightness and when you press Brightness DOWN, it increases the Brightness?
You cannot as it's optimus. I already mentioned in my guide.
Which page are you referring to?
A framebuffer patching is required.
GabyXB
