[Solved] - DSDT - MacIASL does not allow me to apply the patch
Was this thread helpful?
  • Yes
    Votes: 0 0.0%
  • Partially
    Votes: 0 0.0%
  • No
    Votes: 0 0.0%
  • Total voters
    0
@EliteMacx86 Can you send that file to me cause the error persists
@EliteMacx86 Problem is I get 183 Compiling errors when I compile it with macIASL
With the Brightness patch? If so, your DSDT is already patched. I compiled your DSDT and have no errors at all.
Try to be more clear and precise and provide accurate information.
You mean the Brightness buttons don't work?
Ye the brightness buttons does not work and that file returns 183 errors when compiled if you can compile it successfully then can you add the brightness button patch you suggested and share it with me so that I can put it in clover acpi patched
Thats probably clear enough
@EliteMacx86 if it is not going to be fixed easily the you can close the thread
GustavoMdancers
