Upgrade from Mavericks to High Sierra finally successful, but unstable system
You already have it. I didn't change it since January.
  • Wow
Checked your EFI from the last post and its not upto the mark. You should grap an example config.plist from below and then make changes in your config.plist or just prepare a new config.plist from scratch (preferred).
After that, you can map the USB ports and patch the ACPI and all problems should be fixed.
seph3421
