hello mojave installation does not come with installation application only mouse cursor is loading
sumungble
Acer aspire 7745g
I5 m480
Redeon hd5850
10.13.x
  1. Clover (Legacy)
Hi.. (not metal support card) i upgrading high sierra to mojave I said there's a problem
Attach your EFI to check!
Note that for Laptops that has dGPU, you must disable them unless the IGPU can be explicitly disabled in BIOS or is factory disabled from the manufacturer itself.
I have a mux switch in my bios, I can already set it to discrate
I'm not at home now, I'll throw it away from home.
lovos33
