Upgrade from Mavericks to High Sierra finally successful, but unstable system
Yes, there was an issue but its resolved now and queued emails are in process.
Your EFI is not as per the guide. Several things are enabled which aren't meant for your hardware. Also, the DSDT is not patched correctly.
The guide is for installations. There were some additions necessary in postinstall to get WiFi and audio running. The DSDT was created by someone else with the same hardware many years ago and worked fine in Lion and Mavericks. I never tried to patch it.
Macs Fan Control does not recognize any fans. If there is a kext or driver to help with that it might be possible to get rid of the freezes.
See the DSDT patching guide below:
It will not. You'll need the sensors kext. Regarding the random freezes, first extract and patch your ACPI.
I could extract the ACPI files, but preparing the iasl compiler failed. In OSX I would need the Xcode tools, but the laptop is too old. The iMac is also too old to download them because they are not in my purchases. In Linux compiling failed with an error.
Why not use Clover to dump the ACPI files?
As I wrote above I could extract the ACPI files with Clover method, but compiling iasl failed. Never mind, I got it somewhere else. When I try to apply the graphics patch I get the error "invalid object type for reserved name (_PLD: found integer at index 0, buffer required". There are several lines with that and changing numbers. This is the part where I don't know how to proceed.
Attach the Clover native dump to check
Here is the compressed origin folder.
It seems the system is less likely to freeze when running on battery. Perhaps this is merely a coincidence.
Attach a copy of IOReg as well.
Here it is. I had to compress it to upload. Is there a file size limit?
Yes, correct. Can you attach the copy of your current EFI as well?
lovos33
