- Nov 13, 2025
- Dell Latitude E5550
- Intel Core i5-5300U (Broadwell)
- Intel 5500 HD
- 15.x
- Clover (UEFI)
- OpenCore (Legacy)
- MacBook Air
- Windows Phone
I can get the itlwm.kext to work for networking & Internet using Heliport & itlwm.kext.
But could not get the WiFi to work using the Ventura kext AirportItlwm.kext.
Couldn't get Bluetooth to work either.
It works for Ventura both & BT.
In order to be able to boot I have to set IOSkywalkFamily.kext to false in the Kernel Add section, otherwise I get a Kernel panic on boot.
I will try to patch using this as advised:
Find: 5F505330<br>Replace: 58505330<br>Comment: Rename _PS0 to XPS0 (credit: EliteMacx86)
FWIW I am including a link to my dropbox for relevant (EFI partition content, config.plist & IOReg both with spoof & no spoof)
Will appreciate if you fix my config.plist, please note I have to set in Kernel add kext IOSkywalkFamily.kext as false otherwise it won't boot, & the Block section is as you suggested.
Thanks in advance
PS: with the patch it now keeps seeking, but no WiFi listed spots, if it is mandatory to set IOSkywalkFamily.kext to true in the Kernel Add section, it just boots to a kernel panic saying "a relinked copy with different executable UUID already present"
& yes I commented out the Broadcom spoof, doesn't work commented out or not, also reset NVRAM thrice...
Link:
www.dropbox.com
Thanks in advance
Link:
Dropbox
