Airport WiFi on Sequoia for Laptop Dell Latitude E5550
nabilh2020
Premium Member
Dell Latitude E5550
Intel Core i5-5300U (Broadwell)
Intel 5500 HD
15.x
  2. OpenCore (Legacy)
  2. MacBook Air
  3. MacBook Pro
  3. Windows Phone
I can get the itlwm.kext to work for networking & Internet using Heliport & itlwm.kext.
But could not get the WiFi to work using the Ventura kext AirportItlwm.kext.
Couldn't get Bluetooth to work either.
It works for Ventura both & BT.
In order to be able to boot I have to set IOSkywalkFamily.kext to false in the Kernel Add section, otherwise I get a Kernel panic on boot.
I will try to patch using this as advised:
Find: 5F505330<br>Replace: 58505330<br>Comment: Rename _PS0 to XPS0 (credit: EliteMacx86)
FWIW I am including a link to my dropbox for relevant (EFI partition content, config.plist & IOReg both with spoof & no spoof)
Will appreciate if you fix my config.plist, please note I have to set in Kernel add kext IOSkywalkFamily.kext as false otherwise it won't boot, & the Block section is as you suggested.
Thanks in advance
PS: with the patch it now keeps seeking, but no WiFi listed spots, if it is mandatory to set IOSkywalkFamily.kext to true in the Kernel Add section, it just boots to a kernel panic saying "a relinked copy with different executable UUID already present"
& yes I commented out the Broadcom spoof, doesn't work commented out or not, also reset NVRAM thrice...
Link:
This is the corrected config.plist which comments out the Broadcom spoof after the OCLP root parch, still no WiFi despite making the DSDT patch:
Talking to myself...
Anyway, something weird happened, I can't spoof Intel as Broadcom anymore, & Bluetooth worked, config.plist does now work anymore...ill give it a rest for now, got more important fish to fry...
Thanks in advance
Link:
There are severals files. Please attach the main EFI with the Intel WiFi guide described here. It doesn't matter if it doesn't boot or throws Kernel panic.
OK this is the last EFI I got which works with itlwm.kext & bluetooth commenting out all related AirportItlwm.kext related hacks...
but it says the file is too large for the server to process... so I will put up a link to it in my dropbox...
that
