Dell XPS 13 i7-1065G7 Video Memory Stuck at 35MB after patchig DMVT Monterrey
banditch_
Dell XPS 13 7930 2 in 1
i7-1065G7
Iris Plus Graphics
12.x
  1. MacBook Air
EFI: Hardware
  • Model: Dell XPS 13 7390 2-in-1
  • CPU: Intel i7-1065G7 (Ice Lake, Iris Plus G7)
  • iGPU: Device-ID 0x8A52
  • BIOS: 1.9.1 (InsydeH2O)
  • macOS: Monterey
  • Bootloader: OpenCore
Problem
No matter what I do, VRAM is stuck at 35MB and the system behaves like it’s only partially accelerated:
  • Dock is not transparent
  • UI animations stutter badly (Mission Control, app minimization, Safari previews, dictionary popups)
  • System freezes for a few seconds during animations
  • About This Mac shows ~35MB VRAM
  • Clearly not proper Metal acceleration behavior
  • System boots and runs
  • No kernel panics with the correct framebuffer
  • Removing -igfxvesa and fallback args exposes the real issue
  • Graphics acceleration appears partial at best
  • BIOS does not expose DVMT options
  • Used GRUB setup_var to patch DVMT
  • Variables confirmed writable (5C0 / 5C1 etc)
  • DVMT changes do not affect VRAM reporting in macOS
  • Variable 0x785 (mentioned in older XPS guides) exists but reads 0x00
  • Unsure if touching 0x785 on Ice Lake / this BIOS is safe or relevant
  • iGPU correctly identified as Intel Iris Plus Graphics
  • Device-ID shows 8A52
  • AAPL,ig-platform-id sometimes shows ffffffff despite injection
  • Metal plugin loads, but behavior suggests fallback or incorrect memory layout
Questions i have:
  • Why is VRAM hard-capped at 35MB on this Ice Lake system?
  • Is there a missing Ice Lake–specific DVMT or memory variable on Dell XPS 7390?
  • Is BIOS variable 0x785 relevant for Ice Lake, or is that Skylake/Kaby Lake only?
  • Why does the same framebuffer config work on identical hardware but not here?
  • Is this a firmware lock, not a macOS config issue?
  • Can i get acceleration working???
EFI: Hardware
  • macOS: Monterey
Problem
Questions i have:
Attach your EFI to check
Reactions: banditch_
Nightic
