Can't Get Graphics Acceleration work (Dell 5570 - i5 8250U - UHD 620)
thanks for your Quick response ❤️
about the "Kextcashe" file .. how can I generate one ?
Something weird happend when I installed FakeSMC kext and rebooted the system it freezed at that spot so I used my bootable usb (that is working) and it freezed at the same spot (even that the clover on the usb is different and I’m sure it’s working)
I's already in the guide. Type the following in the terminal
sudo kextcache -i/
BIOS Setting is needed. Attach kextcache Output and the PR files.
I can't even get into my OS to generate those files :(
Unable to boot? if so, boot using the USB and attach a kextcache output. For the Clover files, attach it from your system partition.
I have fixed the issue in #32 .... .
Continuing On #29 and the Requested Modifications in #30: This Debug.zip has the Clover that can boot my system (Has No Acceleration) && the Debug information <See #29 for more information>
Still important drivers are missing. And you need to remove all the kexts present in S/L/E.
Once done, boot and attach the new PR files.
I added the drivers exactly like the guide ... If you can tell me what is messing that will be better
GabyXB
