Dell OptiPlex 5080 i7 10700
03hdfatboy
Dell Optiplex 5080
i7 Comet Lake 10700
Intel HD 630
  2. MacBook Air
  3. MacBook Pro
Had to reinstall my OS, it got where it was sluggish and took at least 5 min from cold start to boot to desktop.
Been awhile, running ventura, tried updating to tahoe and will not boot, just crash loops. luckly I cloned the drive so back up in just a few min
Tahoe has a few requirements. Read the installation and troubleshooting guide.
Reactions: 03hdfatboy
Finished, Everything working. VooDooHDA audio. WIFI and BT Screenshot 2025-10-27 at 8.21.28 PM.png Screenshot 2025-10-27 at 8.26.42 PM.png
Fixed random AirDrop issue and screen sharing.
Very Happy with this one. Unless I missed something I now have everything working. Didn't notice the airdrop randomly being unavailable. If you notice anything missing LMK and I'll see what I can do. Tried this on tahoe and it never finishes the update or clean install. so I decided to stay (for now) on Ventura. If you see what i did wrong on OS26 I'm open for advice.
No permissions to view.
Your EFI is not as per the guide and the problems are expected.
Here are a few issues:
- Remove all the OEM DSDT and SSDTs as they are loaded by defaults unless blocked/dropped.
- Use the standard set of SSDTs for CML.
- Remove ResetLogoStatus
- Your hardware has Intel IGPU. Why are you renaming the model to be Radeon Pro 5700XT?
-The framebuffer patching isn't enabled as well.
- Kexts are not loading in sorted order. Mandatory kexts should load first.
- CPUFriend doesn't work alone. To inject the vectors, you require CPUFriendDataProvider.
- Your hardware shouldn't require AppleMCEReporterDisabler.kext.
- On Big Sur and above, AirPortBrcm4360_Injector.kext must be blocked from loading.
- CML has a native support and you shouldn't require injecting Fake CPU ID.
- Disable DisableIoMapper and switch to native VT-d.
- Your hardware has Intel IGPU. Why are you renaming the model to be Radeon Pro 5700XT? just Cause I thought it was cool.
I'll give it a shot when i get a few min
Finally got all the bugs out, as far as I can tell everything works, AirDrop, ScreenShare, Screen Mirror, iMessge, etc
Dell OP 5080 i7 CometLake
1K12JEIJ1
