Black screen on wake
uzurka
Lenovo Thinkpad T550
Intel Core i5 5200U
Intel UHD 5500
12.x
Hi!
I installed MacOS Monterey, using Opencore and Dortania's guide.
Everything works fine except that : When i close the lid, or suspend activity, or whatever turns of the screen, i can't get display back on wake up (open the lid or press mouse / keyboard), backlight turns on, but no display.
Audio is working, MacOS is responding (unlock with password or Apple Watch works), just, backlight turns on but no display.
Just noticed that (closing and reopening the lid multiple times make the display works back SOMETIMES (like 1 out of 20 tries)
My EFI Folder is gitted : https://git.uzurka.fr/Uzurka/Opencore-Lenovo-Thinkpad-T550/src/branch/DEBUG/EFI/OC
Actually using DEBUG Opencore & kexts
Any thoughts ?
Thanks !
Uzurka.
Hi!
Any thoughts ?
Thanks !
Uzurka.
Was the screen ever repaired/replaced?
Oh, indeed there's a geo restriction on what i'm self hosting.
Where are you from ? I'll add your country to the whitelist :)
US. But using a VPN. So, better to remove restriction or attach the EFI here or on Google Drive.
Restriction have been disabled for now. Should work :)
Yes, works now :)
Does this Laptop has dGPU? If so, model please and does it has any Graphics related settings in BIOS?
Do you have the CSM settings in BIOS? If yes, then what have you set it to?
Provide the original ACPI dump.
You can try "Fix black screen on wake from hibernation for Lenovo Thinkpad T490" patch.
김영재
