Sequoia installation loop
peko
Gigabyte GA-Z170-Gaming K3
Intel Core i5-6600K
AMD Radeon RX 5700 XT
10.13.x
Hi!
I'm trying to install Sequoia but after the first reboot it doesn't continue installing. Instead I'm back at Mac OS Recovery.
SecureBootModel is set to disabled
Any help would be greatly appreciated
Hi!
Attach your EFI to check.
Here it is
Here it is
Disable the Renames
alcid=1150 is just invalid.
What's the SSD model you're using for macOS?
Thanks
Disable the Renames
And here I thought I was thorough.
Fixed now though
Renames disabled, using only EnableWriteUnprotector, and alcid=1
Crucial MX300 275GB
Sadly it's still not working.
Thanks
Fixed now though
Crucial MX300 275GB
Attach the updated EFI.
Sure
Enable DisableSecurityPolicy. Reset NVRAM a couple of times. Boot via the installer (using the updated EFI) and then re-erase the disk and try.
Thanks for all the help!
Seems like there some kind of error with my drive, doesn't even show up in the BIOS anymore. Guess I'll have to go shopping.
Then its time to replace the disk!
zaymen
