SOLVED Kernel Panic After Restart/Shutdown
Tech5G5G
Microsoft Surface Pro 7 1866 Motherboard
1.5 GHz Quad-Core Intel Core i7
Intel Iris Plus Graphics 1536 MB
15.x
  1. Other
Hello,
After an upgrade to macOS Tahoe, I able unable to restart or shutdown my Hackintosh normally. Whenever I do, it freezes my Hackintosh. In order to restart or shutdown, I have to press and hold my power button.
Device Specs:
CPU: 1.5 GHz Quad-Core Intel Core i7
GPU: Intel Iris Plus Graphics 1536 MB
RAM: 16 GB 3733 MHz LPDDR4X
Laptop: Microsoft Surface Pro 7
Wifi/BT Card: Intel Wifi & Intel Bluetooth
Touchpad/Keyboard: Microsoft Surface Pro Keyboard
If needed, I can supply panic logs. Also, I think I may be able to restart without a panic if I unplug a port first, although I'm not completely sure.
Hello,
Device Specs:
Attach the EFI you're using.
Great. So, all fixed now?
No, but I marked it as solved because I now know the cause.
mohthearrow
