Help! Asus ROG GL552VX
Still not as per the guide. Here are a few problems:
- Remove ResetLogoStatus.
- Delete all the device properties except for IGPU (PciRoot(0x0)/Pci(0x2,0x0).
- Why are you using all the I2C satellite kexts? Just I2C+HID should be enough. You can remove the PS2 kexts as well (except for the keyboard).
- When you are using UTBMap to map the USB ports, what's the need to inject UIAC.aml, - when its intended to use with USBInjectAll.kext?
- You were mentioned to remove NvmExpressDxe.efi. Why it has not been removed yet?
What's the SSD model you are using?
SSD
KINGSTON SM2280S3G2 480GB
Sorry for the inconvenience, I’ve already cleaned up what you mentioned.
  • EFI_for_elitemac.zip
SSD
Are you able to boot now?
xmax114
