<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>ACPI</key>
<dict>
<key>Add</key>
<array>
<dict>
<key>Comment</key>
<string>SSDT-EC-USBX-DESKTOP.aml</string>
<key>Enabled</key>
<true/>
<key>Path</key>
</dict>
<dict>
<key>Comment</key>
<string>SSDT-PLUG-DRTNIA.aml</string>
<key>Enabled</key>
<true/>
<key>Path</key>
</dict>
</array>
<key>Delete</key>
<array>
<dict>
<key>All</key>
<false/>
<key>Comment</key>
<string>Delete CpuPm</string>
<key>Enabled</key>
<false/>
<key>OemTableId</key>
<data>
Q3B1UG0AAAA=
</data>
<key>TableLength</key>
<integer>0</integer>
<key>TableSignature</key>
<data>
U1NEVA==
</data>
</dict>
<dict>
<key>All</key>
<false/>
<key>Comment</key>
<string>Delete Cpu0Ist</string>
<key>Enabled</key>
<false/>
<data>
Q3B1MElzdAA=
</data>
<data>
U1NEVA==
</data>
</dict>
</array>
<key>Patch</key>
<array>
<dict>
<key>Base</key>
<string></string>
<key>BaseSkip</key>
<key>Comment</key>
<string>Replace one byte sequence with another</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
ESIzRA==
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<data>
</data>
<key>Replace</key>
<data>
RDMiEQ==
</data>
<key>ReplaceMask</key>
<data>
</data>
<key>Skip</key>
<data>
</data>
</dict>
<dict>
<key>Base</key>
<string>\_SB.PCI0.LPCB.HPET</string>
<key>BaseSkip</key>
<key>Comment</key>
<string>HPET _CRS to XCRS</string>
<key>Count</key>
<integer>1</integer>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
X0NSUw==
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<data>
</data>
<key>Replace</key>
<data>
WENSUw==
</data>
<data>
</data>
<key>Skip</key>
<data>
</data>
</dict>
</array>
<key>Quirks</key>
<dict>
<key>FadtEnableReset</key>
<false/>
<key>NormalizeHeaders</key>
<false/>
<key>RebaseRegions</key>
<false/>
<key>ResetHwSig</key>
<false/>
<key>ResetLogoStatus</key>
<false/>
<key>SyncTableIds</key>
<false/>
</dict>
</dict>
<key>Booter</key>
<dict>
<key>MmioWhitelist</key>
<array>
<dict>
<key>Address</key>
<integer>4275159040</integer>
<key>Comment</key>
<string>Haswell: SB_RCBA is a 0x4 page memory region, containing SPI_BASE at 0x3800 (SPI_BASE_ADDRESS)</string>
<key>Enabled</key>
<false/>
</dict>
<dict>
<key>Address</key>
<integer>4278190080</integer>
<key>Comment</key>
<string>Generic: PCI root is a 0x1000 page memory region used by some types of firmware</string>
<key>Enabled</key>
<false/>
</dict>
</array>
<key>Patch</key>
<array>
<dict>
<key>Arch</key>
<string>Any</string>
<key>Comment</key>
<string>macOS to hacOS</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
bWFjT1M=
</data>
<key>Identifier</key>
<string>Apple</string>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<key>Replace</key>
<data>
aGFjT1M=
</data>
<data>
</data>
<key>Skip</key>
</dict>
</array>
<key>Quirks</key>
<dict>
<key>AllowRelocationBlock</key>
<false/>
<key>AvoidRuntimeDefrag</key>
<true/>
<key>ClearTaskSwitchBit</key>
<false/>
<key>DevirtualiseMmio</key>
<false/>
<key>DisableSingleUser</key>
<false/>
<key>DisableVariableWrite</key>
<false/>
<key>DiscardHibernateMap</key>
<false/>
<key>EnableSafeModeSlide</key>
<true/>
<key>EnableWriteUnprotector</key>
<true/>
<key>FixupAppleEfiImages</key>
<false/>
<key>ForceBooterSignature</key>
<false/>
<key>ForceExitBootServices</key>
<false/>
<key>ProtectMemoryRegions</key>
<false/>
<key>ProtectSecureBoot</key>
<false/>
<key>ProtectUefiServices</key>
<false/>
<key>ProvideCustomSlide</key>
<true/>
<key>ProvideMaxSlide</key>
<key>RebuildAppleMemoryMap</key>
<false/>
<key>ResizeAppleGpuBars</key>
<integer>-1</integer>
<key>SetupVirtualMap</key>
<true/>
<key>SignalAppleOS</key>
<false/>
<key>SyncRuntimePermissions</key>
<false/>
</dict>
</dict>
<key>DeviceProperties</key>
<dict>
<key>Add</key>
<dict>
<dict>
<data>
AAASWQ==
</data>
<key>device-id</key>
<data>
AWWQAA==
</data>
<key>framebuffer-con1-alldata</key>
<data>
AQUKAAAIAACHAQAA
</data>
<key>framebuffer-con1-enable</key>
<data>
AQAAAA==
</data>
<key>framebuffer-con2-alldata</key>
<data>
AgQKAAAIAACHAQAA
</data>
<key>framebuffer-con2-enable</key>
<data>
AQAAAA==
</data>
<key>framebuffer-fbmem</key>
<data>
AACQAA==
</data>
<data>
AQAAAA==
</data>
<data>
AAAwAQ==
</data>
</dict>
</dict>
<key>Delete</key>
<dict/>
</dict>
<key>Kernel</key>
<dict>
<key>Add</key>
<array>
<dict>
<key>Arch</key>
<key>BundlePath</key>
<string>Lilu.kext</string>
<key>Comment</key>
<string>Patch engine</string>
<key>Enabled</key>
<true/>
<key>ExecutablePath</key>
<string>Contents/MacOS/Lilu</string>
<key>MaxKernel</key>
<string></string>
<key>MinKernel</key>
<string>8.0.0</string>
<key>PlistPath</key>
<string>Contents/Info.plist</string>
</dict>
<dict>
<key>Arch</key>
<string>VirtualSMC.kext</string>
<key>Comment</key>
<string>SMC emulator</string>
<key>Enabled</key>
<true/>
<string>Contents/MacOS/VirtualSMC</string>
<string></string>
</dict>
<dict>
<key>Arch</key>
<string>x86_64</string>
<string>WhateverGreen.kext</string>
<key>Comment</key>
<string>Video patches</string>
<key>Enabled</key>
<true/>
<string>Contents/MacOS/WhateverGreen</string>
<string></string>
<string>10.0.0</string>
</dict>
<dict>
<key>Arch</key>
<string>USBToolBox.kext</string>
<key>Comment</key>
<string>USBToolBox</string>
<key>Enabled</key>
<true/>
<string>Contents/MacOS/USBToolBox</string>
<string></string>
</dict>
<dict>
<key>Arch</key>
<string>UTBMap.kext</string>
<key>Comment</key>
<string>UTBMap</string>
<key>Enabled</key>
<true/>
<string></string>
</dict>
<dict>
<key>Arch</key>
<string>RealtekRTL8111.kext</string>
<key>Comment</key>
<string>RealtekRTL8111</string>
<key>Enabled</key>
<true/>
<string>Contents/MacOS/RealtekRTL8111</string>
<string></string>
</dict>
<dict>
<key>Arch</key>
<string>AppleALC.kext</string>
<key>Comment</key>
<string>Audio patches</string>
<key>Enabled</key>
<false/>
<string>Contents/MacOS/AppleALC</string>
<string></string>
</dict>
</array>
<key>Block</key>
<array>
<dict>
<key>Arch</key>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<false/>
<string>com.apple.driver.AppleTyMCEDriver</string>
<string></string>
<string></string>
<key>Strategy</key>
<string>Disable</string>
</dict>
<dict>
<key>Arch</key>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<false/>
<string>com.apple.iokit.IOSkywalkFamily</string>
<string></string>
<string>23.0.0</string>
<key>Strategy</key>
<string>Exclude</string>
</dict>
</array>
<key>Emulate</key>
<dict>
<key>Cpuid1Data</key>
<data>
</data>
<key>Cpuid1Mask</key>
<data>
</data>
<key>DummyPowerManagement</key>
<false/>
<string></string>
<string></string>
</dict>
<key>Force</key>
<array>
<dict>
<key>Arch</key>
<string>System/Library/Extensions/IONetworkingFamily.kext</string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<false/>
<string>Contents/MacOS/IONetworkingFamily</string>
<string>com.apple.iokit.IONetworkingFamily</string>
<string>13.99.99</string>
<string></string>
</dict>
</array>
<key>Kernel</key>
<dict>
<key>Add</key>
<array>
<dict>
<key>Arch</key>
<key>Comment</key>
<key>Enabled</key>
<true/>
<string></string>
</dict>
<dict>
<key>Arch</key>
<key>Comment</key>
<key>Enabled</key>
<true/>
<string></string>
</dict>
<dict>
<key>Arch</key>
<key>Comment</key>
<key>Enabled</key>
<true/>
<string></string>
</dict>
<dict>
<key>Arch</key>
<key>Comment</key>
<key>Enabled</key>
<true/>
<string></string>
</dict>
<dict>
<key>Arch</key>
<key>Comment</key>
<key>Enabled</key>
<true/>
<string></string>
</dict>
<dict>
<key>Arch</key>
<key>Comment</key>
<key>Enabled</key>
<true/>
<string></string>
</dict>
<dict>
<key>Arch</key>
<key>Comment</key>
<key>Enabled</key>
<false/>
<string></string>
</dict>
</array>
<key>Block</key>
<array>
<dict>
<key>Arch</key>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<false/>
<string></string>
<string></string>
<key>Strategy</key>
</dict>
<dict>
<key>Arch</key>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<false/>
<string></string>
<key>Strategy</key>
</dict>
</array>
<key>Emulate</key>
<dict>
<data>
</data>
<data>
</data>
<false/>
<string></string>
<string></string>
</dict>
<key>Force</key>
<array>
<dict>
<key>Arch</key>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<false/>
<string></string>
</dict>
</array>
<key>Patch</key>
<array>
<dict>
<key>Arch</key>
<key>Base</key>
<string>__ZN8AppleRTC18setupDateTimeAlarmEPK11RTCDateTime</string>
<key>Comment</key>
<string>Disable RTC wake scheduling</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<string>com.apple.driver.AppleRTC</string>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string>19.0.0</string>
<key>Replace</key>
<data>
ww==
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<string>_AcpiOsVprintf</string>
<key>Comment</key>
<string>Disable ACPI logging</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<string>com.apple.driver.AppleACPIPlatform</string>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string>18.5.0</string>
<key>Replace</key>
<data>
ww==
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<string>__ZN11BCM5701Enet14getAdapterInfoEv</string>
<key>Comment</key>
<string>Broadcom BCM57785 patch</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
6AAA//9miYMABQAA
</data>
<string>com.apple.iokit.AppleBCM5701Ethernet</string>
<key>Limit</key>
<key>Mask</key>
<data>
/wAA////////////
</data>
<string>19.9.9</string>
<string></string>
<key>Replace</key>
<data>
uLQWAABmiYMABQAA
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<string>__ZN24IOBluetoothHCIController5startEP9IOService</string>
<key>Comment</key>
<string>Disable Bluetooth entirely</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<string>com.apple.iokit.IOBluetoothFamily</string>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
ww==
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<string>_panic</string>
<key>Comment</key>
<string>Send panic string to serial port</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<string>kernel</string>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
MfaKD4TJdQT/xrEKZrr9A+yoIHT7Zrr4A4jI
7kj/x4X2dN/r/g==
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<string>_kernel_debug_string_early</string>
<key>Comment</key>
<string>Send early prints to serial port</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
7kj/x4X2dN/D
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<string>_disable_serial_output</string>
<key>Comment</key>
<string>Enable early serial output on RELEASE kernel</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
AA==
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<string>_vstart</string>
<key>Comment</key>
<string>Print K and dead loop</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
sUtmuv0D7KggdPtmuvgDiMjusQpmuv0D7Kgg
dPtmuvgDiMju6/4=
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<string>Early reboot</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
McCwBrr5DAAA7uv+
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<string>_early_random</string>
<key>Comment</key>
<string>SurPlus v1 - PART 1 of 2 - Patch read_erandom (inlined in _early_random)</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
AHQjSIs=
</data>
<key>Limit</key>
<integer>800</integer>
<key>Mask</key>
<data>
</data>
<string>21.1.0</string>
<string>20.4.0</string>
<key>Replace</key>
<data>
AOsjSIs=
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<string>_register_and_init_prng</string>
<key>Comment</key>
<string>SurPlus v1 - PART 2 of 2 - Patch register_and_init_prng</string>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
ukgBAAAx9g==
</data>
<key>Limit</key>
<integer>256</integer>
<key>Mask</key>
<data>
</data>
<key>Replace</key>
<data>
ukgBAADrBQ==
</data>
<data>
</data>
<key>Skip</key>
</dict>
</array>
<key>Quirks</key>
<dict>
<key>AppleCpuPmCfgLock</key>
<false/>
<key>AppleXcpmCfgLock</key>
<true/>
<key>AppleXcpmExtraMsrs</key>
<false/>
<key>AppleXcpmForceBoost</key>
<false/>
<key>CustomPciSerialDevice</key>
<false/>
<key>CustomSMBIOSGuid</key>
<false/>
<key>DisableIoMapper</key>
<true/>
<key>DisableIoMapperMapping</key>
<false/>
<key>DisableLinkeditJettison</key>
<true/>
<key>DisableRtcChecksum</key>
<false/>
<key>ExtendBTFeatureFlags</key>
<false/>
<key>ExternalDiskIcons</key>
<false/>
<key>ForceAquantiaEthernet</key>
<false/>
<key>ForceSecureBootScheme</key>
<false/>
<key>IncreasePciBarSize</key>
<false/>
<key>LapicKernelPanic</key>
<false/>
<key>LegacyCommpage</key>
<false/>
<key>PanicNoKextDump</key>
<true/>
<key>PowerTimeoutKernelPanic</key>
<true/>
<key>ProvideCurrentCpuInfo</key>
<false/>
<key>SetApfsTrimTimeout</key>
<key>ThirdPartyDrives</key>
<false/>
<key>XhciPortLimit</key>
<true/>
</dict>
<key>Scheme</key>
<dict>
<key>CustomKernel</key>
<false/>
<key>FuzzyMatch</key>
<true/>
<key>KernelArch</key>
<string>Auto</string>
<key>KernelCache</key>
</dict>
</dict>
<key>Patch</key>
<array>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<key>Replace</key>
<data>
ww==
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<key>Replace</key>
<data>
ww==
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
6AAA//9miYMABQAA
</data>
<key>Limit</key>
<key>Mask</key>
<data>
/wAA////////////
</data>
<string></string>
<key>Replace</key>
<data>
uLQWAABmiYMABQAA
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
ww==
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
MfaKD4TJdQT/xrEKZrr9A+yoIHT7Zrr4A4jI7kj/x4X2
dN/r/g==
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
dN/D
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
AA==
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
sUtmuv0D7KggdPtmuvgDiMjusQpmuv0D7KggdPtmuvgD
iMju6/4=
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<string></string>
<string></string>
<key>Replace</key>
<data>
McCwBrr5DAAA7uv+
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
AHQjSIs=
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<key>Replace</key>
<data>
AOsjSIs=
</data>
<data>
</data>
<key>Skip</key>
</dict>
<dict>
<key>Arch</key>
<key>Base</key>
<key>Comment</key>
<key>Count</key>
<key>Enabled</key>
<false/>
<key>Find</key>
<data>
ukgBAAAx9g==
</data>
<key>Limit</key>
<key>Mask</key>
<data>
</data>
<key>Replace</key>
<data>
ukgBAADrBQ==
</data>
<data>
</data>
<key>Skip</key>
</dict>
</array>
<key>Quirks</key>
<dict>
<false/>
<true/>
<false/>
<false/>
<false/>
<false/>
<true/>
<false/>
<true/>
<false/>
<false/>
<false/>
<false/>
<false/>
<false/>
<false/>
<false/>
<true/>
<true/>
<false/>
<false/>
<true/>
</dict>
<key>Scheme</key>
<dict>
<false/>
<true/>
</dict>
</dict>
<key>Misc</key>
<dict>
<key>BlessOverride</key>
<array/>
<key>Boot</key>
<dict>
<key>ConsoleAttributes</key>
<key>HibernateMode</key>
<string>None</string>
<key>HibernateSkipsPicker</key>
<false/>
<key>HideAuxiliary</key>
<true/>
<key>InstanceIdentifier</key>
<string></string>
<key>LauncherOption</key>
<string>Disabled</string>
<key>LauncherPath</key>
<string>Default</string>
<key>PickerAttributes</key>
<integer>17</integer>
<key>PickerAudioAssist</key>
<false/>
<key>PickerMode</key>
<string>Builtin</string>
<key>PickerVariant</key>
<key>PollAppleHotKeys</key>
<false/>
<key>ShowPicker</key>
<true/>
<key>TakeoffDelay</key>
<key>Timeout</key>
<integer>5</integer>
</dict>
<key>Debug</key>
<dict>
<key>AppleDebug</key>
<true/>
<key>ApplePanic</key>
<true/>
<key>DisableWatchDog</key>
<false/>
<key>DisplayDelay</key>
<key>DisplayLevel</key>
<integer>2147483650</integer>
<key>LogModules</key>
<string>*</string>
<key>SysReport</key>
<false/>
<key>Target</key>
<integer>67</integer>
</dict>
<key>Entries</key>
<array>
<dict>
<key>Arguments</key>
<string></string>
<key>Auxiliary</key>
<false/>
<key>Comment</key>
<string>Not signed for security reasons</string>
<key>Enabled</key>
<false/>
<key>Flavour</key>
<key>Name</key>
<string>CustomOS</string>
<key>Path</key>
<string>PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/NVMe(0x1,11-22-33-44-55-66-77-88)/HD(1,GPT,00000000-0000-0000-0000-000000000000,0x800,0x64000)/\EFI\BOOT\BOOTX64.EFI</string>
<key>TextMode</key>
<false/>
</dict>
</array>
<key>Security</key>
<dict>
<key>AllowSetDefault</key>
<true/>
<key>ApECID</key>
<key>AuthRestart</key>
<false/>
<key>BlacklistAppleUpdate</key>
<true/>
<key>DmgLoading</key>
<string>Signed</string>
<key>EnablePassword</key>
<false/>
<key>ExposeSensitiveData</key>
<integer>6</integer>
<key>HaltLevel</key>
<integer>2147483648</integer>
<key>PasswordHash</key>
<data>
</data>
<key>PasswordSalt</key>
<data>
</data>
<key>ScanPolicy</key>
<key>SecureBootModel</key>
<key>Vault</key>
<string>Optional</string>
</dict>
<key>Serial</key>
<dict>
<key>Init</key>
<false/>
<key>Override</key>
<false/>
</dict>
<key>Tools</key>
<array>
<dict>
<string></string>
<true/>
<key>Comment</key>
<key>Enabled</key>
<false/>
<key>Flavour</key>
<string>OpenShell:UEFIShell:Shell</string>
<key>FullNvramAccess</key>
<false/>
<key>Name</key>
<string>UEFI Shell</string>
<key>Path</key>
<string>OpenShell.efi</string>
<key>RealPath</key>
<false/>
<key>TextMode</key>
<false/>
</dict>
<dict>
<string></string>
<true/>
<key>Comment</key>
<string>Memory testing utility</string>
<key>Enabled</key>
<false/>
<key>Flavour</key>
<string>MemTest</string>
<false/>
<key>Name</key>
<string>memtest86</string>
<key>Path</key>
<string>memtest86/BOOTX64.efi</string>
<key>RealPath</key>
<true/>
<key>TextMode</key>
<false/>
</dict>
<dict>
<string>Shutdown</string>
<true/>
<key>Comment</key>
<string>Perform shutdown</string>
<key>Enabled</key>
<false/>
<key>Flavour</key>
<false/>
<key>Name</key>
<key>Path</key>
<string>ResetSystem.efi</string>
<key>RealPath</key>
<false/>
<key>TextMode</key>
<false/>
</dict>
</array>
</dict>
<key>NVRAM</key>
<dict>
<key>Add</key>
<dict>
<key>4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14</key>
<dict>
<key>DefaultBackgroundColor</key>
<data>
AAAAAA==
</data>
</dict>
<key>4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102</key>
<dict>
<key>rtc-blacklist</key>
<data>
</data>
</dict>
<key>7C436110-AB2A-4BBB-A880-FE41995C9F82</key>
<dict>
<key>#INFO (prev-lang:kbd)</key>
<string>en:252 (ABC), set 656e3a323532</string>
<key>ForceDisplayRotationInEFI</key>
<key>SystemAudioVolume</key>
<data>
Rg==
</data>
<key>boot-args</key>
<string>-v keepsyms=1 debug=0x100 alcid=1</string>
<key>csr-active-config</key>
<data>
AAAAAA==
</data>
<key>prev-lang:kbd</key>
<data>
ZW4tVVM6MA==
</data>
<key>run-efi-updater</key>
<string>No</string>
</dict>
</dict>
<key>Delete</key>
<dict>
<array>
<string>DefaultBackgroundColor</string>
</array>
<array>
<string>rtc-blacklist</string>
</array>
<array>
<string>boot-args</string>
<string>ForceDisplayRotationInEFI</string>
</array>
</dict>
<key>LegacyOverwrite</key>
<false/>
<key>LegacySchema</key>
<dict>
<array>
<string>EFILoginHiDPI</string>
<string>EFIBluetoothDelay</string>
<string>LocationServicesEnabled</string>
<string>SystemAudioVolume</string>
<string>SystemAudioVolumeDB</string>
<string>SystemAudioVolumeSaved</string>
<string>bluetoothActiveControllerInfo</string>
<string>bluetoothInternalControllerInfo</string>
<string>flagstate</string>
<string>fmm-computer-name</string>
<string>fmm-mobileme-token-FMM</string>
<string>fmm-mobileme-token-FMM-BridgeHasAccount</string>
<string>nvda_drv</string>
<string>prev-lang:kbd</string>
<string>backlight-level</string>
<string>BootCampHD</string>
</array>
<key>8BE4DF61-93CA-11D2-AA0D-00E098032B8C</key>
<array>
<string>Boot0080</string>
<string>Boot0081</string>
<string>Boot0082</string>
<string>BootNext</string>
<string>BootOrder</string>
</array>
</dict>
<key>WriteFlash</key>
<true/>
</dict>
<key>PlatformInfo</key>
<dict>
<key>Automatic</key>
<true/>
<key>CustomMemory</key>
<false/>
<key>Generic</key>
<dict>
<key>AdviseFeatures</key>
<false/>
<key>MLB</key>
<string>M0000000000000001</string>
<key>MaxBIOSVersion</key>
<false/>
<key>ProcessorType</key>
<key>ROM</key>
<data>
ESIzRFVm
</data>
<key>SpoofVendor</key>
<true/>
<key>SystemMemoryStatus</key>
<key>SystemProductName</key>
<string>iMac18,1</string>
<key>SystemSerialNumber</key>
<string>W00000000001</string>
<key>SystemUUID</key>
<string>00000000-0000-0000-0000-000000000000</string>
</dict>
<key>UpdateDataHub</key>
<true/>
<key>UpdateNVRAM</key>
<true/>
<key>UpdateSMBIOS</key>
<true/>
<key>UpdateSMBIOSMode</key>
<string>Create</string>
<key>UseRawUuidEncoding</key>
<false/>
</dict>
<key>UEFI</key>
<dict>
<key>APFS</key>
<dict>
<key>EnableJumpstart</key>
<true/>
<key>GlobalConnect</key>
<false/>
<key>HideVerbose</key>
<true/>
<key>JumpstartHotPlug</key>
<false/>
<key>MinDate</key>
<key>MinVersion</key>
</dict>
<key>AppleInput</key>
<dict>
<key>AppleEvent</key>
<key>CustomDelays</key>
<false/>
<key>GraphicsInputMirroring</key>
<true/>
<key>KeyInitialDelay</key>
<integer>50</integer>
<key>KeySubsequentDelay</key>
<key>PointerDwellClickTimeout</key>
<key>PointerDwellDoubleClickTimeout</key>
<key>PointerDwellRadius</key>
<key>PointerPollMask</key>
<key>PointerPollMax</key>
<integer>80</integer>
<key>PointerPollMin</key>
<integer>10</integer>
<key>PointerSpeedDiv</key>
<key>PointerSpeedMul</key>
</dict>
<key>Audio</key>
<dict>
<key>AudioCodec</key>
<key>AudioDevice</key>
<string>PciRoot(0x0)/Pci(0x1b,0x0)</string>
<key>AudioOutMask</key>
<key>AudioSupport</key>
<false/>
<key>DisconnectHda</key>
<false/>
<key>MaximumGain</key>
<integer>-15</integer>
<key>MinimumAssistGain</key>
<integer>-30</integer>
<key>MinimumAudibleGain</key>
<integer>-55</integer>
<key>PlayChime</key>
<key>ResetTrafficClass</key>
<false/>
<key>SetupDelay</key>
</dict>
<key>ConnectDrivers</key>
<true/>
<key>Drivers</key>
<array>
<dict>
<string></string>
<key>Comment</key>
<string>Hfs+ Driver</string>
<key>Enabled</key>
<true/>
<key>LoadEarly</key>
<false/>
<key>Path</key>
<string>HfsPlus.efi</string>
</dict>
<dict>
<string></string>
<key>Comment</key>
<string></string>
<key>Enabled</key>
<true/>
<false/>
<key>Path</key>
<string>OpenRuntime.efi</string>
</dict>
</array>
<key>Input</key>
<dict>
<key>KeyFiltering</key>
<false/>
<key>KeyForgetThreshold</key>
<key>KeySupport</key>
<true/>
<key>KeySupportMode</key>
<key>KeySwap</key>
<false/>
<key>PointerSupport</key>
<false/>
<key>PointerSupportMode</key>
<string>ASUS</string>
<key>TimerResolution</key>
<integer>50000</integer>
</dict>
<key>Output</key>
<dict>
<key>ClearScreenOnModeSwitch</key>
<false/>
<key>ConsoleFont</key>
<string></string>
<key>ConsoleMode</key>
<string></string>
<key>DirectGopRendering</key>
<false/>
<key>ForceResolution</key>
<false/>
<key>GopBurstMode</key>
<false/>
<key>GopPassThrough</key>
<key>IgnoreTextInGraphics</key>
<false/>
<key>InitialMode</key>
<key>ProvideConsoleGop</key>
<true/>
<key>ReconnectGraphicsOnConnect</key>
<false/>
<key>ReconnectOnResChange</key>
<false/>
<key>ReplaceTabWithSpace</key>
<false/>
<key>Resolution</key>
<string>Max</string>
<key>SanitiseClearScreen</key>
<false/>
<key>TextRenderer</key>
<string>BuiltinGraphics</string>
<key>UIScale</key>
<key>UgaPassThrough</key>
<false/>
</dict>
<key>ProtocolOverrides</key>
<dict>
<key>AppleAudio</key>
<false/>
<key>AppleBootPolicy</key>
<false/>
<key>AppleDebugLog</key>
<false/>
<key>AppleEg2Info</key>
<false/>
<key>AppleFramebufferInfo</key>
<false/>
<key>AppleImageConversion</key>
<false/>
<key>AppleImg4Verification</key>
<false/>
<key>AppleKeyMap</key>
<false/>
<key>AppleRtcRam</key>
<false/>
<key>AppleSecureBoot</key>
<false/>
<key>AppleSmcIo</key>
<false/>
<key>AppleUserInterfaceTheme</key>
<false/>
<key>DataHub</key>
<false/>
<false/>
<key>FirmwareVolume</key>
<true/>
<key>HashServices</key>
<false/>
<key>OSInfo</key>
<false/>
<key>PciIo</key>
<false/>
<key>UnicodeCollation</key>
<false/>
</dict>
<key>Quirks</key>
<dict>
<key>ActivateHpetSupport</key>
<false/>
<key>DisableSecurityPolicy</key>
<false/>
<key>EnableVectorAcceleration</key>
<true/>
<key>EnableVmx</key>
<false/>
<key>ExitBootServicesDelay</key>
<key>ForceOcWriteFlash</key>
<false/>
<key>ForgeUefiSupport</key>
<false/>
<key>IgnoreInvalidFlexRatio</key>
<false/>
<key>ReleaseUsbOwnership</key>
<true/>
<key>ReloadOptionRoms</key>
<false/>
<key>RequestBootVarRouting</key>
<true/>
<key>ResizeGpuBars</key>
<key>ResizeUsePciRbIo</key>
<false/>
<key>ShimRetainProtocol</key>
<false/>
<key>TscSyncTimeout</key>
<key>UnblockFsConnect</key>
<false/>
</dict>
<key>ReservedMemory</key>
<array>
<dict>
<key>Address</key>
<integer>268435456</integer>
<key>Comment</key>
<string>HD3000: IGPU memory corruption errata</string>
<key>Enabled</key>
<false/>
<key>Size</key>
<key>Type</key>
<string>Reserved</string>
</dict>
<dict>
<key>Address</key>
<integer>569344</integer>
<key>Comment</key>
<string>Fix black screen on wake from hibernation for Lenovo Thinkpad T490</string>
<key>Enabled</key>
<false/>
<key>Size</key>
<integer>4096</integer>
<key>Type</key>
<string>RuntimeCode</string>
</dict>
</array>
<key>Unload</key>
<array/>
</dict>
</dict>
</plist>
