SOLVED BlackScreen after validating root dmg
Something is wrong. Your config had iMac SMBIOS but Hackimtool shows different.
I tried "Mac Mini 8,1" like in my friend config, before i used iMac 18,1 and 18,3.
For test*
For test*
Okay. Just updated the message. Kindly review it.
Monterey (12.7.6)
DVMT - 64MB
For my case getting EDID only via ubunut livecd?
Same.
My tests give result with this:
  • framebuffer-con0-alldata | Data | port 1 (ie. `01000900 00040000 C7030000`)
  • framebuffer-con1-alldata | Data | port 2 (ie. `02000A00 00040000 C7030000`)
  • framebuffer-con2-alldata | Data | port 3 (ie. `03060800 00080000 C7030000`)
with this monitor not showing "no signal", only black screen. os doesn’t boot, VNC not working. (but only without EDID writed)
tried 87010000 for value #3 like in dortania guide.
In config only for AAPL00 writed EDID, but i tried for all.
I see display in settings (color profile), but no video on it and not listed in ioreg:
EDID:
https://drive.google.com/file/d/1Tp_EgZfx_hTCTCP9mPqiHQVuTdl2JvvW/view?usp=sharing
IOReg:
https://drive.google.com/file/d/1cYdYw3iC3iOd7WMUPbz5dd64OeYtUW_a/view?usp=sharing
Config:
https://drive.google.com/file/d/1STmRxY3BcJ4V7q_IMWqkcXP24fjzqA9f/view?usp=sharing
Okay. Now monitor is showing picture, but no graphics acceleration.
If delete device-id, monitor stopping work.
EDID not change anything, monitor showing like Unknown Display and not hw accel.
your config.plist is very wrong
why have you duplicated loads of sections:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
    <key>ACPI</key>
    <dict>
        <key>Add</key>
        <array>
            <dict>
                <key>Comment</key>
                <string>SSDT-EC-USBX-DESKTOP.aml</string>
                <key>Enabled</key>
                <true/>
                <key>Path</key>
            </dict>
            <dict>
                <key>Comment</key>
                <string>SSDT-PLUG-DRTNIA.aml</string>
                <key>Enabled</key>
                <true/>
                <key>Path</key>
            </dict>
        </array>
        <key>Delete</key>
        <array>
            <dict>
                <key>All</key>
                <false/>
                <key>Comment</key>
                <string>Delete CpuPm</string>
                <key>Enabled</key>
                <false/>
                <key>OemTableId</key>
                <data>
                Q3B1UG0AAAA=
                </data>
                <key>TableLength</key>
                <integer>0</integer>
                <key>TableSignature</key>
                <data>
                U1NEVA==
                </data>
            </dict>
            <dict>
                <key>All</key>
                <false/>
                <key>Comment</key>
                <string>Delete Cpu0Ist</string>
                <key>Enabled</key>
                <false/>
                <data>
                Q3B1MElzdAA=
                </data>
                <data>
                U1NEVA==
                </data>
            </dict>
        </array>
        <key>Patch</key>
        <array>
            <dict>
                <key>Base</key>
                <string></string>
                <key>BaseSkip</key>
                <key>Comment</key>
                <string>Replace one byte sequence with another</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                ESIzRA==
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <data>
                </data>
                <key>Replace</key>
                <data>
                RDMiEQ==
                </data>
                <key>ReplaceMask</key>
                <data>
                </data>
                <key>Skip</key>
                <data>
                </data>
            </dict>
            <dict>
                <key>Base</key>
                <string>\_SB.PCI0.LPCB.HPET</string>
                <key>BaseSkip</key>
                <key>Comment</key>
                <string>HPET _CRS to XCRS</string>
                <key>Count</key>
                <integer>1</integer>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                X0NSUw==
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <data>
                </data>
                <key>Replace</key>
                <data>
                WENSUw==
                </data>
                <data>
                </data>
                <key>Skip</key>
                <data>
                </data>
            </dict>
        </array>
        <key>Quirks</key>
        <dict>
            <key>FadtEnableReset</key>
            <false/>
            <key>NormalizeHeaders</key>
            <false/>
            <key>RebaseRegions</key>
            <false/>
            <key>ResetHwSig</key>
            <false/>
            <key>ResetLogoStatus</key>
            <false/>
            <key>SyncTableIds</key>
            <false/>
        </dict>
    </dict>
    <key>Booter</key>
    <dict>
        <key>MmioWhitelist</key>
        <array>
            <dict>
                <key>Address</key>
                <integer>4275159040</integer>
                <key>Comment</key>
                <string>Haswell: SB_RCBA is a 0x4 page memory region, containing SPI_BASE at 0x3800 (SPI_BASE_ADDRESS)</string>
                <key>Enabled</key>
                <false/>
            </dict>
            <dict>
                <key>Address</key>
                <integer>4278190080</integer>
                <key>Comment</key>
                <string>Generic: PCI root is a 0x1000 page memory region used by some types of firmware</string>
                <key>Enabled</key>
                <false/>
            </dict>
        </array>
        <key>Patch</key>
        <array>
            <dict>
                <key>Arch</key>
                <string>Any</string>
                <key>Comment</key>
                <string>macOS to hacOS</string>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                bWFjT1M=
                </data>
                <key>Identifier</key>
                <string>Apple</string>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <key>Replace</key>
                <data>
                aGFjT1M=
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
        </array>
        <key>Quirks</key>
        <dict>
            <key>AllowRelocationBlock</key>
            <false/>
            <key>AvoidRuntimeDefrag</key>
            <true/>
            <key>ClearTaskSwitchBit</key>
            <false/>
            <key>DevirtualiseMmio</key>
            <false/>
            <key>DisableSingleUser</key>
            <false/>
            <key>DisableVariableWrite</key>
            <false/>
            <key>DiscardHibernateMap</key>
            <false/>
            <key>EnableSafeModeSlide</key>
            <true/>
            <key>EnableWriteUnprotector</key>
            <true/>
            <key>FixupAppleEfiImages</key>
            <false/>
            <key>ForceBooterSignature</key>
            <false/>
            <key>ForceExitBootServices</key>
            <false/>
            <key>ProtectMemoryRegions</key>
            <false/>
            <key>ProtectSecureBoot</key>
            <false/>
            <key>ProtectUefiServices</key>
            <false/>
            <key>ProvideCustomSlide</key>
            <true/>
            <key>ProvideMaxSlide</key>
            <key>RebuildAppleMemoryMap</key>
            <false/>
            <key>ResizeAppleGpuBars</key>
            <integer>-1</integer>
            <key>SetupVirtualMap</key>
            <true/>
            <key>SignalAppleOS</key>
            <false/>
            <key>SyncRuntimePermissions</key>
            <false/>
        </dict>
    </dict>
    <key>DeviceProperties</key>
    <dict>
        <key>Add</key>
        <dict>
            <dict>
                <data>
                AAASWQ==
                </data>
                <key>device-id</key>
                <data>
                AWWQAA==
                </data>
                <key>framebuffer-con1-alldata</key>
                <data>
                AQUKAAAIAACHAQAA
                </data>
                <key>framebuffer-con1-enable</key>
                <data>
                AQAAAA==
                </data>
                <key>framebuffer-con2-alldata</key>
                <data>
                AgQKAAAIAACHAQAA
                </data>
                <key>framebuffer-con2-enable</key>
                <data>
                AQAAAA==
                </data>
                <key>framebuffer-fbmem</key>
                <data>
                AACQAA==
                </data>
                <data>
                AQAAAA==
                </data>
                <data>
                AAAwAQ==
                </data>
            </dict>
        </dict>
        <key>Delete</key>
        <dict/>
    </dict>
    <key>Kernel</key>
    <dict>
        <key>Add</key>
        <array>
            <dict>
                <key>Arch</key>
                <key>BundlePath</key>
                <string>Lilu.kext</string>
                <key>Comment</key>
                <string>Patch engine</string>
                <key>Enabled</key>
                <true/>
                <key>ExecutablePath</key>
                <string>Contents/MacOS/Lilu</string>
                <key>MaxKernel</key>
                <string></string>
                <key>MinKernel</key>
                <string>8.0.0</string>
                <key>PlistPath</key>
                <string>Contents/Info.plist</string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>VirtualSMC.kext</string>
                <key>Comment</key>
                <string>SMC emulator</string>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/VirtualSMC</string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>x86_64</string>
                <string>WhateverGreen.kext</string>
                <key>Comment</key>
                <string>Video patches</string>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/WhateverGreen</string>
                <string></string>
                <string>10.0.0</string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>USBToolBox.kext</string>
                <key>Comment</key>
                <string>USBToolBox</string>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/USBToolBox</string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>UTBMap.kext</string>
                <key>Comment</key>
                <string>UTBMap</string>
                <key>Enabled</key>
                <true/>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>RealtekRTL8111.kext</string>
                <key>Comment</key>
                <string>RealtekRTL8111</string>
                <key>Enabled</key>
                <true/>
                <string>Contents/MacOS/RealtekRTL8111</string>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <string>AppleALC.kext</string>
                <key>Comment</key>
                <string>Audio patches</string>
                <key>Enabled</key>
                <false/>
                <string>Contents/MacOS/AppleALC</string>
                <string></string>
            </dict>
        </array>
        <key>Block</key>
        <array>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <false/>
                <string>com.apple.driver.AppleTyMCEDriver</string>
                <string></string>
                <string></string>
                <key>Strategy</key>
                <string>Disable</string>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <false/>
                <string>com.apple.iokit.IOSkywalkFamily</string>
                <string></string>
                <string>23.0.0</string>
                <key>Strategy</key>
                <string>Exclude</string>
            </dict>
        </array>
        <key>Emulate</key>
        <dict>
            <key>Cpuid1Data</key>
            <data>
            </data>
            <key>Cpuid1Mask</key>
            <data>
            </data>
            <key>DummyPowerManagement</key>
            <false/>
            <string></string>
            <string></string>
        </dict>
        <key>Force</key>
        <array>
            <dict>
                <key>Arch</key>
                <string>System/Library/Extensions/IONetworkingFamily.kext</string>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <false/>
                <string>Contents/MacOS/IONetworkingFamily</string>
                <string>com.apple.iokit.IONetworkingFamily</string>
                <string>13.99.99</string>
                <string></string>
            </dict>
        </array>
        <key>Kernel</key>
        <dict>
            <key>Add</key>
            <array>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <false/>
                    <string></string>
                </dict>
            </array>
            <key>Block</key>
            <array>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <string></string>
                    <key>Enabled</key>
                    <false/>
                    <string></string>
                    <string></string>
                    <key>Strategy</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <string></string>
                    <key>Enabled</key>
                    <false/>
                    <string></string>
                    <key>Strategy</key>
                </dict>
            </array>
            <key>Emulate</key>
            <dict>
                <data>
                </data>
                <data>
                </data>
                <false/>
                <string></string>
                <string></string>
            </dict>
            <key>Force</key>
            <array>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <string></string>
                    <key>Enabled</key>
                    <false/>
                    <string></string>
                </dict>
            </array>
            <key>Patch</key>
            <array>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>__ZN8AppleRTC18setupDateTimeAlarmEPK11RTCDateTime</string>
                    <key>Comment</key>
                    <string>Disable RTC wake scheduling</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <string>com.apple.driver.AppleRTC</string>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string>19.0.0</string>
                    <key>Replace</key>
                    <data>
                    ww==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>_AcpiOsVprintf</string>
                    <key>Comment</key>
                    <string>Disable ACPI logging</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <string>com.apple.driver.AppleACPIPlatform</string>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string>18.5.0</string>
                    <key>Replace</key>
                    <data>
                    ww==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>__ZN11BCM5701Enet14getAdapterInfoEv</string>
                    <key>Comment</key>
                    <string>Broadcom BCM57785 patch</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    6AAA//9miYMABQAA
                    </data>
                    <string>com.apple.iokit.AppleBCM5701Ethernet</string>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    /wAA////////////
                    </data>
                    <string>19.9.9</string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    uLQWAABmiYMABQAA
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>__ZN24IOBluetoothHCIController5startEP9IOService</string>
                    <key>Comment</key>
                    <string>Disable Bluetooth entirely</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <string>com.apple.iokit.IOBluetoothFamily</string>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    ww==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>_panic</string>
                    <key>Comment</key>
                    <string>Send panic string to serial port</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <string>kernel</string>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    MfaKD4TJdQT/xrEKZrr9A+yoIHT7Zrr4A4jI
                    7kj/x4X2dN/r/g==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>_kernel_debug_string_early</string>
                    <key>Comment</key>
                    <string>Send early prints to serial port</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    7kj/x4X2dN/D
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>_disable_serial_output</string>
                    <key>Comment</key>
                    <string>Enable early serial output on RELEASE kernel</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    AA==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>_vstart</string>
                    <key>Comment</key>
                    <string>Print K and dead loop</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    sUtmuv0D7KggdPtmuvgDiMjusQpmuv0D7Kgg
                    dPtmuvgDiMju6/4=
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <string>Early reboot</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    McCwBrr5DAAA7uv+
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>_early_random</string>
                    <key>Comment</key>
                    <string>SurPlus v1 - PART 1 of 2 - Patch read_erandom (inlined in _early_random)</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    AHQjSIs=
                    </data>
                    <key>Limit</key>
                    <integer>800</integer>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string>21.1.0</string>
                    <string>20.4.0</string>
                    <key>Replace</key>
                    <data>
                    AOsjSIs=
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <string>_register_and_init_prng</string>
                    <key>Comment</key>
                    <string>SurPlus v1 - PART 2 of 2 - Patch register_and_init_prng</string>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    ukgBAAAx9g==
                    </data>
                    <key>Limit</key>
                    <integer>256</integer>
                    <key>Mask</key>
                    <data>
                    </data>
                    <key>Replace</key>
                    <data>
                    ukgBAADrBQ==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
            </array>
            <key>Quirks</key>
            <dict>
                <key>AppleCpuPmCfgLock</key>
                <false/>
                <key>AppleXcpmCfgLock</key>
                <true/>
                <key>AppleXcpmExtraMsrs</key>
                <false/>
                <key>AppleXcpmForceBoost</key>
                <false/>
                <key>CustomPciSerialDevice</key>
                <false/>
                <key>CustomSMBIOSGuid</key>
                <false/>
                <key>DisableIoMapper</key>
                <true/>
                <key>DisableIoMapperMapping</key>
                <false/>
                <key>DisableLinkeditJettison</key>
                <true/>
                <key>DisableRtcChecksum</key>
                <false/>
                <key>ExtendBTFeatureFlags</key>
                <false/>
                <key>ExternalDiskIcons</key>
                <false/>
                <key>ForceAquantiaEthernet</key>
                <false/>
                <key>ForceSecureBootScheme</key>
                <false/>
                <key>IncreasePciBarSize</key>
                <false/>
                <key>LapicKernelPanic</key>
                <false/>
                <key>LegacyCommpage</key>
                <false/>
                <key>PanicNoKextDump</key>
                <true/>
                <key>PowerTimeoutKernelPanic</key>
                <true/>
                <key>ProvideCurrentCpuInfo</key>
                <false/>
                <key>SetApfsTrimTimeout</key>
                <key>ThirdPartyDrives</key>
                <false/>
                <key>XhciPortLimit</key>
                <true/>
            </dict>
            <key>Scheme</key>
            <dict>
                <key>CustomKernel</key>
                <false/>
                <key>FuzzyMatch</key>
                <true/>
                <key>KernelArch</key>
                <string>Auto</string>
                <key>KernelCache</key>
            </dict>
        </dict>
        <key>Patch</key>
        <array>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <key>Replace</key>
                <data>
                ww==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <key>Replace</key>
                <data>
                ww==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                6AAA//9miYMABQAA
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                /wAA////////////
                </data>
                <string></string>
                <key>Replace</key>
                <data>
                uLQWAABmiYMABQAA
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                ww==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                MfaKD4TJdQT/xrEKZrr9A+yoIHT7Zrr4A4jI7kj/x4X2
                dN/r/g==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                dN/D
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                AA==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                sUtmuv0D7KggdPtmuvgDiMjusQpmuv0D7KggdPtmuvgD
                iMju6/4=
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                McCwBrr5DAAA7uv+
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                AHQjSIs=
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <key>Replace</key>
                <data>
                AOsjSIs=
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                ukgBAAAx9g==
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <key>Replace</key>
                <data>
                ukgBAADrBQ==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
        </array>
        <key>Quirks</key>
        <dict>
            <false/>
            <true/>
            <false/>
            <false/>
            <false/>
            <false/>
            <true/>
            <false/>
            <true/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <true/>
            <true/>
            <false/>
            <false/>
            <true/>
        </dict>
        <key>Scheme</key>
        <dict>
            <false/>
            <true/>
        </dict>
    </dict>
    <key>Misc</key>
    <dict>
        <key>BlessOverride</key>
        <array/>
        <key>Boot</key>
        <dict>
            <key>ConsoleAttributes</key>
            <key>HibernateMode</key>
            <string>None</string>
            <key>HibernateSkipsPicker</key>
            <false/>
            <key>HideAuxiliary</key>
            <true/>
            <key>InstanceIdentifier</key>
            <string></string>
            <key>LauncherOption</key>
            <string>Disabled</string>
            <key>LauncherPath</key>
            <string>Default</string>
            <key>PickerAttributes</key>
            <integer>17</integer>
            <key>PickerAudioAssist</key>
            <false/>
            <key>PickerMode</key>
            <string>Builtin</string>
            <key>PickerVariant</key>
            <key>PollAppleHotKeys</key>
            <false/>
            <key>ShowPicker</key>
            <true/>
            <key>TakeoffDelay</key>
            <key>Timeout</key>
            <integer>5</integer>
        </dict>
        <key>Debug</key>
        <dict>
            <key>AppleDebug</key>
            <true/>
            <key>ApplePanic</key>
            <true/>
            <key>DisableWatchDog</key>
            <false/>
            <key>DisplayDelay</key>
            <key>DisplayLevel</key>
            <integer>2147483650</integer>
            <key>LogModules</key>
            <string>*</string>
            <key>SysReport</key>
            <false/>
            <key>Target</key>
            <integer>67</integer>
        </dict>
        <key>Entries</key>
        <array>
            <dict>
                <key>Arguments</key>
                <string></string>
                <key>Auxiliary</key>
                <false/>
                <key>Comment</key>
                <string>Not signed for security reasons</string>
                <key>Enabled</key>
                <false/>
                <key>Flavour</key>
                <key>Name</key>
                <string>CustomOS</string>
                <key>Path</key>
                <string>PciRoot(0x0)/Pci(0x1,0x1)/Pci(0x0,0x0)/NVMe(0x1,11-22-33-44-55-66-77-88)/HD(1,GPT,00000000-0000-0000-0000-000000000000,0x800,0x64000)/\EFI\BOOT\BOOTX64.EFI</string>
                <key>TextMode</key>
                <false/>
            </dict>
        </array>
        <key>Security</key>
        <dict>
            <key>AllowSetDefault</key>
            <true/>
            <key>ApECID</key>
            <key>AuthRestart</key>
            <false/>
            <key>BlacklistAppleUpdate</key>
            <true/>
            <key>DmgLoading</key>
            <string>Signed</string>
            <key>EnablePassword</key>
            <false/>
            <key>ExposeSensitiveData</key>
            <integer>6</integer>
            <key>HaltLevel</key>
            <integer>2147483648</integer>
            <key>PasswordHash</key>
            <data>
            </data>
            <key>PasswordSalt</key>
            <data>
            </data>
            <key>ScanPolicy</key>
            <key>SecureBootModel</key>
            <key>Vault</key>
            <string>Optional</string>
        </dict>
        <key>Serial</key>
        <dict>
            <key>Init</key>
            <false/>
            <key>Override</key>
            <false/>
        </dict>
        <key>Tools</key>
        <array>
            <dict>
                <string></string>
                <true/>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Flavour</key>
                <string>OpenShell:UEFIShell:Shell</string>
                <key>FullNvramAccess</key>
                <false/>
                <key>Name</key>
                <string>UEFI Shell</string>
                <key>Path</key>
                <string>OpenShell.efi</string>
                <key>RealPath</key>
                <false/>
                <key>TextMode</key>
                <false/>
            </dict>
            <dict>
                <string></string>
                <true/>
                <key>Comment</key>
                <string>Memory testing utility</string>
                <key>Enabled</key>
                <false/>
                <key>Flavour</key>
                <string>MemTest</string>
                <false/>
                <key>Name</key>
                <string>memtest86</string>
                <key>Path</key>
                <string>memtest86/BOOTX64.efi</string>
                <key>RealPath</key>
                <true/>
                <key>TextMode</key>
                <false/>
            </dict>
            <dict>
                <string>Shutdown</string>
                <true/>
                <key>Comment</key>
                <string>Perform shutdown</string>
                <key>Enabled</key>
                <false/>
                <key>Flavour</key>
                <false/>
                <key>Name</key>
                <key>Path</key>
                <string>ResetSystem.efi</string>
                <key>RealPath</key>
                <false/>
                <key>TextMode</key>
                <false/>
            </dict>
        </array>
    </dict>
    <key>NVRAM</key>
    <dict>
        <key>Add</key>
        <dict>
            <key>4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14</key>
            <dict>
                <key>DefaultBackgroundColor</key>
                <data>
                AAAAAA==
                </data>
            </dict>
            <key>4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102</key>
            <dict>
                <key>rtc-blacklist</key>
                <data>
                </data>
            </dict>
            <key>7C436110-AB2A-4BBB-A880-FE41995C9F82</key>
            <dict>
                <key>#INFO (prev-lang:kbd)</key>
                <string>en:252 (ABC), set 656e3a323532</string>
                <key>ForceDisplayRotationInEFI</key>
                <key>SystemAudioVolume</key>
                <data>
                Rg==
                </data>
                <key>boot-args</key>
                <string>-v keepsyms=1 debug=0x100 alcid=1</string>
                <key>csr-active-config</key>
                <data>
                AAAAAA==
                </data>
                <key>prev-lang:kbd</key>
                <data>
                ZW4tVVM6MA==
                </data>
                <key>run-efi-updater</key>
                <string>No</string>
            </dict>
        </dict>
        <key>Delete</key>
        <dict>
            <array>
                <string>DefaultBackgroundColor</string>
            </array>
            <array>
                <string>rtc-blacklist</string>
            </array>
            <array>
                <string>boot-args</string>
                <string>ForceDisplayRotationInEFI</string>
            </array>
        </dict>
        <key>LegacyOverwrite</key>
        <false/>
        <key>LegacySchema</key>
        <dict>
            <array>
                <string>EFILoginHiDPI</string>
                <string>EFIBluetoothDelay</string>
                <string>LocationServicesEnabled</string>
                <string>SystemAudioVolume</string>
                <string>SystemAudioVolumeDB</string>
                <string>SystemAudioVolumeSaved</string>
                <string>bluetoothActiveControllerInfo</string>
                <string>bluetoothInternalControllerInfo</string>
                <string>flagstate</string>
                <string>fmm-computer-name</string>
                <string>fmm-mobileme-token-FMM</string>
                <string>fmm-mobileme-token-FMM-BridgeHasAccount</string>
                <string>nvda_drv</string>
                <string>prev-lang:kbd</string>
                <string>backlight-level</string>
                <string>BootCampHD</string>
            </array>
            <key>8BE4DF61-93CA-11D2-AA0D-00E098032B8C</key>
            <array>
                <string>Boot0080</string>
                <string>Boot0081</string>
                <string>Boot0082</string>
                <string>BootNext</string>
                <string>BootOrder</string>
            </array>
        </dict>
        <key>WriteFlash</key>
        <true/>
    </dict>
    <key>PlatformInfo</key>
    <dict>
        <key>Automatic</key>
        <true/>
        <key>CustomMemory</key>
        <false/>
        <key>Generic</key>
        <dict>
            <key>AdviseFeatures</key>
            <false/>
            <key>MLB</key>
            <string>M0000000000000001</string>
            <key>MaxBIOSVersion</key>
            <false/>
            <key>ProcessorType</key>
            <key>ROM</key>
            <data>
            ESIzRFVm
            </data>
            <key>SpoofVendor</key>
            <true/>
            <key>SystemMemoryStatus</key>
            <key>SystemProductName</key>
            <string>iMac18,1</string>
            <key>SystemSerialNumber</key>
            <string>W00000000001</string>
            <key>SystemUUID</key>
            <string>00000000-0000-0000-0000-000000000000</string>
        </dict>
        <key>UpdateDataHub</key>
        <true/>
        <key>UpdateNVRAM</key>
        <true/>
        <key>UpdateSMBIOS</key>
        <true/>
        <key>UpdateSMBIOSMode</key>
        <string>Create</string>
        <key>UseRawUuidEncoding</key>
        <false/>
    </dict>
    <key>UEFI</key>
    <dict>
        <key>APFS</key>
        <dict>
            <key>EnableJumpstart</key>
            <true/>
            <key>GlobalConnect</key>
            <false/>
            <key>HideVerbose</key>
            <true/>
            <key>JumpstartHotPlug</key>
            <false/>
            <key>MinDate</key>
            <key>MinVersion</key>
        </dict>
        <key>AppleInput</key>
        <dict>
            <key>AppleEvent</key>
            <key>CustomDelays</key>
            <false/>
            <key>GraphicsInputMirroring</key>
            <true/>
            <key>KeyInitialDelay</key>
            <integer>50</integer>
            <key>KeySubsequentDelay</key>
            <key>PointerDwellClickTimeout</key>
            <key>PointerDwellDoubleClickTimeout</key>
            <key>PointerDwellRadius</key>
            <key>PointerPollMask</key>
            <key>PointerPollMax</key>
            <integer>80</integer>
            <key>PointerPollMin</key>
            <integer>10</integer>
            <key>PointerSpeedDiv</key>
            <key>PointerSpeedMul</key>
        </dict>
        <key>Audio</key>
        <dict>
            <key>AudioCodec</key>
            <key>AudioDevice</key>
            <string>PciRoot(0x0)/Pci(0x1b,0x0)</string>
            <key>AudioOutMask</key>
            <key>AudioSupport</key>
            <false/>
            <key>DisconnectHda</key>
            <false/>
            <key>MaximumGain</key>
            <integer>-15</integer>
            <key>MinimumAssistGain</key>
            <integer>-30</integer>
            <key>MinimumAudibleGain</key>
            <integer>-55</integer>
            <key>PlayChime</key>
            <key>ResetTrafficClass</key>
            <false/>
            <key>SetupDelay</key>
        </dict>
        <key>ConnectDrivers</key>
        <true/>
        <key>Drivers</key>
        <array>
            <dict>
                <string></string>
                <key>Comment</key>
                <string>Hfs+ Driver</string>
                <key>Enabled</key>
                <true/>
                <key>LoadEarly</key>
                <false/>
                <key>Path</key>
                <string>HfsPlus.efi</string>
            </dict>
            <dict>
                <string></string>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <true/>
                <false/>
                <key>Path</key>
                <string>OpenRuntime.efi</string>
            </dict>
        </array>
        <key>Input</key>
        <dict>
            <key>KeyFiltering</key>
            <false/>
            <key>KeyForgetThreshold</key>
            <key>KeySupport</key>
            <true/>
            <key>KeySupportMode</key>
            <key>KeySwap</key>
            <false/>
            <key>PointerSupport</key>
            <false/>
            <key>PointerSupportMode</key>
            <string>ASUS</string>
            <key>TimerResolution</key>
            <integer>50000</integer>
        </dict>
        <key>Output</key>
        <dict>
            <key>ClearScreenOnModeSwitch</key>
            <false/>
            <key>ConsoleFont</key>
            <string></string>
            <key>ConsoleMode</key>
            <string></string>
            <key>DirectGopRendering</key>
            <false/>
            <key>ForceResolution</key>
            <false/>
            <key>GopBurstMode</key>
            <false/>
            <key>GopPassThrough</key>
            <key>IgnoreTextInGraphics</key>
            <false/>
            <key>InitialMode</key>
            <key>ProvideConsoleGop</key>
            <true/>
            <key>ReconnectGraphicsOnConnect</key>
            <false/>
            <key>ReconnectOnResChange</key>
            <false/>
            <key>ReplaceTabWithSpace</key>
            <false/>
            <key>Resolution</key>
            <string>Max</string>
            <key>SanitiseClearScreen</key>
            <false/>
            <key>TextRenderer</key>
            <string>BuiltinGraphics</string>
            <key>UIScale</key>
            <key>UgaPassThrough</key>
            <false/>
        </dict>
        <key>ProtocolOverrides</key>
        <dict>
            <key>AppleAudio</key>
            <false/>
            <key>AppleBootPolicy</key>
            <false/>
            <key>AppleDebugLog</key>
            <false/>
            <key>AppleEg2Info</key>
            <false/>
            <key>AppleFramebufferInfo</key>
            <false/>
            <key>AppleImageConversion</key>
            <false/>
            <key>AppleImg4Verification</key>
            <false/>
            <key>AppleKeyMap</key>
            <false/>
            <key>AppleRtcRam</key>
            <false/>
            <key>AppleSecureBoot</key>
            <false/>
            <key>AppleSmcIo</key>
            <false/>
            <key>AppleUserInterfaceTheme</key>
            <false/>
            <key>DataHub</key>
            <false/>
            <false/>
            <key>FirmwareVolume</key>
            <true/>
            <key>HashServices</key>
            <false/>
            <key>OSInfo</key>
            <false/>
            <key>PciIo</key>
            <false/>
            <key>UnicodeCollation</key>
            <false/>
        </dict>
        <key>Quirks</key>
        <dict>
            <key>ActivateHpetSupport</key>
            <false/>
            <key>DisableSecurityPolicy</key>
            <false/>
            <key>EnableVectorAcceleration</key>
            <true/>
            <key>EnableVmx</key>
            <false/>
            <key>ExitBootServicesDelay</key>
            <key>ForceOcWriteFlash</key>
            <false/>
            <key>ForgeUefiSupport</key>
            <false/>
            <key>IgnoreInvalidFlexRatio</key>
            <false/>
            <key>ReleaseUsbOwnership</key>
            <true/>
            <key>ReloadOptionRoms</key>
            <false/>
            <key>RequestBootVarRouting</key>
            <true/>
            <key>ResizeGpuBars</key>
            <key>ResizeUsePciRbIo</key>
            <false/>
            <key>ShimRetainProtocol</key>
            <false/>
            <key>TscSyncTimeout</key>
            <key>UnblockFsConnect</key>
            <false/>
        </dict>
        <key>ReservedMemory</key>
        <array>
            <dict>
                <key>Address</key>
                <integer>268435456</integer>
                <key>Comment</key>
                <string>HD3000: IGPU memory corruption errata</string>
                <key>Enabled</key>
                <false/>
                <key>Size</key>
                <key>Type</key>
                <string>Reserved</string>
            </dict>
            <dict>
                <key>Address</key>
                <integer>569344</integer>
                <key>Comment</key>
                <string>Fix black screen on wake from hibernation for Lenovo Thinkpad T490</string>
                <key>Enabled</key>
                <false/>
                <key>Size</key>
                <integer>4096</integer>
                <key>Type</key>
                <string>RuntimeCode</string>
            </dict>
        </array>
        <key>Unload</key>
        <array/>
    </dict>
</dict>
</plist>
<dict>
    <key>ACPI</key>
    <dict>
        <key>Add</key>
        <array>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <key>Path</key>
            </dict>
            <dict>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <key>Path</key>
            </dict>
        </array>
        <key>Delete</key>
        <array>
            <dict>
                <key>All</key>
                <false/>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <data>
                Q3B1UG0AAAA=
                </data>
                <data>
                U1NEVA==
                </data>
            </dict>
            <dict>
                <key>All</key>
                <false/>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <data>
                Q3B1MElzdAA=
                </data>
                <data>
                U1NEVA==
                </data>
            </dict>
        </array>
        <key>Patch</key>
        <array>
            <dict>
                <key>Base</key>
                <string></string>
                <key>BaseSkip</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                ESIzRA==
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <data>
                </data>
                <key>Replace</key>
                <data>
                RDMiEQ==
                </data>
                <data>
                </data>
                <key>Skip</key>
                <data>
                </data>
            </dict>
            <dict>
                <key>Base</key>
                <key>BaseSkip</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                X0NSUw==
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <data>
                </data>
                <key>Replace</key>
                <data>
                WENSUw==
                </data>
                <data>
                </data>
                <key>Skip</key>
                <data>
                </data>
            </dict>
        </array>
        <key>Quirks</key>
        <dict>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
        </dict>
    </dict>
    <key>Booter</key>
    <dict>
        <array>
            <dict>
                <key>Address</key>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
            </dict>
            <dict>
                <key>Address</key>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
            </dict>
        </array>
        <key>Patch</key>
        <array>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                bWFjT1M=
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <key>Replace</key>
                <data>
                aGFjT1M=
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
        </array>
        <key>Quirks</key>
        <dict>
            <false/>
            <true/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <true/>
            <true/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <true/>
            <false/>
            <true/>
            <false/>
            <false/>
        </dict>
    </dict>
    <dict>
        <key>Add</key>
        <dict>
            <dict>
                <data>
                AAASWQ==
                </data>
                <data>
                AWWQAA==
                </data>
                <data>
                AQUKAAAIAACHAQAA
                </data>
                <data>
                AQAAAA==
                </data>
                <data>
                AgQKAAAIAACHAQAA
                </data>
                <data>
                AQAAAA==
                </data>
                <data>
                AACQAA==
                </data>
                <data>
                AQAAAA==
                </data>
                <data>
                AAAwAQ==
                </data>
            </dict>
        </dict>
        <key>Delete</key>
        <dict/>
    </dict>
    <key>Kernel</key>
    <dict>
        <key>Add</key>
        <array>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <string></string>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <string></string>
            </dict>
        </array>
        <key>Block</key>
        <array>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <false/>
                <string></string>
                <string></string>
                <key>Strategy</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <false/>
                <string></string>
                <key>Strategy</key>
            </dict>
        </array>
        <key>Emulate</key>
        <dict>
            <data>
            </data>
            <data>
            </data>
            <false/>
            <string></string>
            <string></string>
        </dict>
        <key>Force</key>
        <array>
            <dict>
                <key>Arch</key>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <false/>
                <string></string>
            </dict>
        </array>
        <key>Kernel</key>
        <dict>
            <key>Add</key>
            <array>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <true/>
                    <string></string>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <key>Enabled</key>
                    <false/>
                    <string></string>
                </dict>
            </array>
            <key>Block</key>
            <array>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <string></string>
                    <key>Enabled</key>
                    <false/>
                    <string></string>
                    <string></string>
                    <key>Strategy</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <string></string>
                    <key>Enabled</key>
                    <false/>
                    <string></string>
                    <key>Strategy</key>
                </dict>
            </array>
            <key>Emulate</key>
            <dict>
                <data>
                </data>
                <data>
                </data>
                <false/>
                <string></string>
                <string></string>
            </dict>
            <key>Force</key>
            <array>
                <dict>
                    <key>Arch</key>
                    <key>Comment</key>
                    <string></string>
                    <key>Enabled</key>
                    <false/>
                    <string></string>
                </dict>
            </array>
            <key>Patch</key>
            <array>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    ww==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <key>Replace</key>
                    <data>
                    ww==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    6AAA//9miYMABQAA
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    /wAA////////////
                    </data>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    uLQWAABmiYMABQAA
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    ww==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    7kj/x4X2dN/r/g==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    7kj/x4X2dN/D
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    AA==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    dPtmuvgDiMju6/4=
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <string></string>
                    <string></string>
                    <key>Replace</key>
                    <data>
                    McCwBrr5DAAA7uv+
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    AHQjSIs=
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <key>Replace</key>
                    <data>
                    AOsjSIs=
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
                <dict>
                    <key>Arch</key>
                    <key>Base</key>
                    <key>Comment</key>
                    <key>Count</key>
                    <key>Enabled</key>
                    <false/>
                    <key>Find</key>
                    <data>
                    ukgBAAAx9g==
                    </data>
                    <key>Limit</key>
                    <key>Mask</key>
                    <data>
                    </data>
                    <key>Replace</key>
                    <data>
                    ukgBAADrBQ==
                    </data>
                    <data>
                    </data>
                    <key>Skip</key>
                </dict>
            </array>
            <key>Quirks</key>
            <dict>
                <false/>
                <true/>
                <false/>
                <false/>
                <false/>
                <false/>
                <true/>
                <false/>
                <true/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <false/>
                <true/>
                <true/>
                <false/>
                <false/>
                <true/>
            </dict>
            <key>Scheme</key>
            <dict>
                <false/>
                <true/>
            </dict>
        </dict>
        <key>Patch</key>
        <array>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <key>Replace</key>
                <data>
                ww==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <key>Replace</key>
                <data>
                ww==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                6AAA//9miYMABQAA
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                /wAA////////////
                </data>
                <string></string>
                <key>Replace</key>
                <data>
                uLQWAABmiYMABQAA
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                ww==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                dN/r/g==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                dN/D
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                AA==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                iMju6/4=
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <string></string>
                <string></string>
                <key>Replace</key>
                <data>
                McCwBrr5DAAA7uv+
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                AHQjSIs=
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <key>Replace</key>
                <data>
                AOsjSIs=
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
            <dict>
                <key>Arch</key>
                <key>Base</key>
                <key>Comment</key>
                <key>Count</key>
                <key>Enabled</key>
                <false/>
                <key>Find</key>
                <data>
                ukgBAAAx9g==
                </data>
                <key>Limit</key>
                <key>Mask</key>
                <data>
                </data>
                <key>Replace</key>
                <data>
                ukgBAADrBQ==
                </data>
                <data>
                </data>
                <key>Skip</key>
            </dict>
        </array>
        <key>Quirks</key>
        <dict>
            <false/>
            <true/>
            <false/>
            <false/>
            <false/>
            <false/>
            <true/>
            <false/>
            <true/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <true/>
            <true/>
            <false/>
            <false/>
            <true/>
        </dict>
        <key>Scheme</key>
        <dict>
            <false/>
            <true/>
        </dict>
    </dict>
    <key>Misc</key>
    <dict>
        <array/>
        <key>Boot</key>
        <dict>
            <false/>
            <true/>
            <string></string>
            <false/>
            <false/>
            <true/>
            <key>Timeout</key>
        </dict>
        <key>Debug</key>
        <dict>
            <true/>
            <true/>
            <false/>
            <string>*</string>
            <false/>
            <key>Target</key>
        </dict>
        <key>Entries</key>
        <array>
            <dict>
                <string></string>
                <false/>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Flavour</key>
                <key>Name</key>
                <key>Path</key>
                <key>TextMode</key>
                <false/>
            </dict>
        </array>
        <key>Security</key>
        <dict>
            <true/>
            <key>ApECID</key>
            <false/>
            <true/>
            <false/>
            <data>
            </data>
            <data>
            </data>
            <key>Vault</key>
        </dict>
        <key>Serial</key>
        <dict>
            <key>Init</key>
            <false/>
            <key>Override</key>
            <false/>
        </dict>
        <key>Tools</key>
        <array>
            <dict>
                <string></string>
                <true/>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Flavour</key>
                <false/>
                <key>Name</key>
                <key>Path</key>
                <key>RealPath</key>
                <false/>
                <key>TextMode</key>
                <false/>
            </dict>
            <dict>
                <string></string>
                <true/>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Flavour</key>
                <false/>
                <key>Name</key>
                <key>Path</key>
                <key>RealPath</key>
                <true/>
                <key>TextMode</key>
                <false/>
            </dict>
            <dict>
                <true/>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Flavour</key>
                <false/>
                <key>Name</key>
                <key>Path</key>
                <key>RealPath</key>
                <false/>
                <key>TextMode</key>
                <false/>
            </dict>
        </array>
    </dict>
    <key>NVRAM</key>
    <dict>
        <key>Add</key>
        <dict>
            <dict>
                <data>
                AAAAAA==
                </data>
            </dict>
            <dict>
                <data>
                </data>
            </dict>
            <dict>
                <data>
                Rg==
                </data>
                <data>
                AAAAAA==
                </data>
                <data>
                ZW4tVVM6MA==
                </data>
                <string>No</string>
            </dict>
        </dict>
        <key>Delete</key>
        <dict>
            <array>
            </array>
            <array>
            </array>
            <array>
            </array>
        </dict>
        <false/>
        <dict>
            <array>
            </array>
            <array>
            </array>
        </dict>
        <true/>
    </dict>
    <dict>
        <true/>
        <false/>
        <key>Generic</key>
        <dict>
            <false/>
            <key>MLB</key>
            <false/>
            <key>ROM</key>
            <data>
            ESIzRFVm
            </data>
            <true/>
        </dict>
        <true/>
        <true/>
        <true/>
        <false/>
    </dict>
    <key>UEFI</key>
    <dict>
        <key>APFS</key>
        <dict>
            <true/>
            <false/>
            <true/>
            <false/>
            <key>MinDate</key>
        </dict>
        <dict>
            <false/>
            <true/>
        </dict>
        <key>Audio</key>
        <dict>
            <false/>
            <false/>
            <false/>
        </dict>
        <true/>
        <key>Drivers</key>
        <array>
            <dict>
                <string></string>
                <key>Comment</key>
                <key>Enabled</key>
                <true/>
                <false/>
                <key>Path</key>
            </dict>
            <dict>
                <string></string>
                <key>Comment</key>
                <string></string>
                <key>Enabled</key>
                <true/>
                <false/>
                <key>Path</key>
            </dict>
        </array>
        <key>Input</key>
        <dict>
            <false/>
            <true/>
            <key>KeySwap</key>
            <false/>
            <false/>
        </dict>
        <key>Output</key>
        <dict>
            <false/>
            <string></string>
            <string></string>
            <false/>
            <false/>
            <false/>
            <false/>
            <true/>
            <false/>
            <false/>
            <false/>
            <false/>
            <key>UIScale</key>
            <false/>
        </dict>
        <dict>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <false/>
            <key>DataHub</key>
            <false/>
            <false/>
            <true/>
            <false/>
            <key>OSInfo</key>
            <false/>
            <key>PciIo</key>
            <false/>
            <false/>
        </dict>
        <key>Quirks</key>
        <dict>
            <false/>
            <false/>
            <true/>
            <false/>
            <false/>
            <false/>
            <false/>
            <true/>
            <false/>
            <true/>
            <false/>
            <false/>
            <false/>
        </dict>
        <array>
            <dict>
                <key>Address</key>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Size</key>
                <key>Type</key>
            </dict>
            <dict>
                <key>Address</key>
                <key>Comment</key>
                <key>Enabled</key>
                <false/>
                <key>Size</key>
                <key>Type</key>
            </dict>
        </array>
        <key>Unload</key>
        <array/>
    </dict>
</dict>
</plist>
Yes, I may have blotted out a duplicate line somewhere - I've had many iterations, could well have accidentally left.
But its not reason why graphics not work.
CIZART
