Fenvi T919 Wifi is not working on Sequoia 15.5
HI, somehow i disabled the SIP by booting into recovery and then using terminal. by this OCLP start showing Patches Option. later i again modified the config.plist as per your youtube video. but my OS crashed and even using recovery usb it was unable to boot i am attaching the video. then i totally replace the efi folder with recovery usb efi by booting into windows and using a tool to open macos efi. i am now attaching the previous efi folder and config.plist which was not booting after modification 1752637243904.png Screenshot 2025-07-15 at 11.46.36 PM.png
HI, somehow i disabled the SIP by booting into recovery and then using terminal. by this OCLP start showing Patches Option. later i again modified the config.plist as per your youtube video. but my OS crashed and even using recovery usb it was unable to boot i am attaching the video. then i totally replace the efi folder with recovery usb efi by booting into windows and using a tool to open macos efi. i am now attaching the previous efi folder and config.plist which was not booting after modificationView attachment 9648View attachment 9653
It's still not as per the guide. Here are a few issues:
Here are a few issues. Make the following changes to your config.plist:
Disable FadtEnableReset
Disable RebaseRegions
Disable ResetLogoStatus
Set ResizeAppleGpuBars to -1.
Remove AppleMCEReporterDisabler.kext, AtherosE2200Ethernet.kext, RealtekRTL8111.kext, and IntelMausi.kext
You should either use AMFIPass.kext or amfi=0x80. Never both!
first of all i've to thankyou so much for this detailed reply. this is the first time in 4 months that i've edited my config.plist and boot isn't crashed.
wifi is not showing available networks although its turned on now. i tried to apply patches from OCLP but its not giving me option. i went into recovery mode and again give command of csrutil disable. but its not again giving me the option for root patches after even disabling SIP and firefox is start working which i think disabling SIP is not working properly . i am attaching the screenshoots and efi as well
Screenshot 2025-07-18 at 7.50.35 AM.png Screenshot 2025-07-18 at 7.41.22 AM.png
View attachment 9657View attachment 9658
sir you were busy so i gpt about this problem and it says that maybe you opencore version is not up to dated then i watch your youtube video that how to upedate opencore and do the same, but after that my mac is not booting up and config.plist have following errors. i tried to again replace the full efi folder including config.plist which was previously working well and attached in above reply. but mac os is still not booting up. why? i am not getting it cuz whenever any issue happens i replace the full efi folder with last working folder.
sir i will pay you 10 to 20 dollars if you make me efi folder according to my hardware specification, someone on internet is offering same but actually i believe you, you will not scam me
AMFI still shows enabled. Update the AMFIPass.kext to latest and ensure you reset NVRAM properly. Once the AMFI is disabled, OCLP should give you the option to patch. If AMFIPass does not work, then use the bootarg to disable and ensure you disable the AMFIPass.kext when you use bootarg.
That's now how you update the OC. Check the guide on the forum for step by step. You can find the link below:
You can either use Manual Method or the OCAT Method.
okay i've done what you was guiding me and thankyou ! wifi starts working. but there is a problem happened then. my firefox was not working so i again remove the boot arg and enabled the AMFIpass.kext in config.plist. and my mac os got crashed. i tried everything. using recovery usb, booting into windows, replacing whole efi folder from efi drive with old efi folder resting nvram multiple times. but mac os is not booting but in loop i am attaching the video with it
Attach the EFI to check!
okay here is the last efi which was working well,
but as much i think its not the issue of efi becoause i've tried different efis like my recovery usb which have the basic efi in it but its not booting with it too. neither its booting with any efi. which are priviously working
rbrb
