Fenvi T919 Wifi is not working on Sequoia 15.5
zabardastibyabbas
MSI Mortar B760M
Core I5 12700
RTX 5700 XT
  1. iMac Pro
Hello,
previously i've installed ventura but it was giving update so i installed sequoia. Then after update bluetooth is working but wifi of fenvi t919 is not working. i've followed you full video on youtube (
) in you guide how to do this but it did not work becuse when i come to the step of paching it says that can not patch becouse AMFI is enabled, so all the video got in vain cuz steps didn't come to end Moreover after following your video and editing my config.plist its not working. mac os is not booting up and i used my recovery usb to boot it. i am attaching my config.plist here can you see what is the problem. further more i updated the opencore but now its not giving me the clear nvram option while booting only giving me the option of selecting my os. kindly guide my and thanks in advance.
Screenshot 2025-06-30 at 8.48.45 PM.png Screenshot 2025-06-30 at 8.48.00 PM.png Screenshot 2025-06-30 at 8.48.26 PM.png
Hello,
View attachment 9614View attachment 9615View attachment 9616
Firstly, the config.plist is not as per the guide.
Secondly, the SIP is not disabled which is causing the issue. Once you disable SIP, OCLP should show that the patches are available.
sir i have spend alot time now on this but i am not getting what is wrong with it. i am unable to fix my config.plist can you edit me a config.plist? on which i can apply lagacy pathc. i'll be thankful
Already mentioned what's wrong and what you need to do.
Sir i am Dumb !! its been now more then 4 months i am trying to configure mac os on my windows pc , whenever i little bit edit my config.plist, system stop boothing. today i come to now that maybe i need AirPortBrcm4360 in my plist
i know i cannot fix this please do this for me do you need money for this?? tell me maybe i can afford you 🥺. otherwise the only way left is that i install back the os ventura so my things start working
Se disabling SIP in the wifi guide.
YOUR WIFI GUIDE IS NOT OPENING, GIVE ME VALID LINJK PLEASE.
Never provided you the link. However, here is the link to the guide:
Reactions: zabardastibyabbas
i spend my all day doning this now its not working even after disabling SIP as per guide OCLP is not showing option of patching.
now i am installing mac os ventura again becaouse there is no option left, its been 4 months and i am unable to find out where the problem is and you are not even willing to make a config.plist file for me so i think its better to install mac os ventura again
Attach the config.plist to check.
Continuing and following the guide or giving up is entirely your choice!
mollyshard
