Sound HDMI failed
gna6l4fsc
Asrock B560M pro4
Intel I7-11700
AMD RX6600XT
15.x
Hello dear Hack'ov users, there is a problem that the sound disappears after the computer goes to sleep, I turn it on and there is no sound via HDMI...?
Does this happen only after entering sleep and then wake?
Yes, I've already found the bug)) in the open VLC player, if you close it before going to sleep, the sound remains normal
So, only VLC causes the issue?
Hi! The problem has not stopped, only overloading once or twice helps, the sound disappears on the speakers of the monitor (ASUS MX239), which is connected to the video card via hdmi (AMD Radeon RX 6600 XT 8 GB).kext = AppleALC - layout-id:66 is installedWhat could be the problem?(
Attach EFI to check!
EFI
kutumbaba
