SOLVED HP 600 G1 Core i7 No Sound
I'll look into it tomorrow my config.plist disable ResetLogoStatus and FixupApplefiImages quirk and mapping my USB port. I patch my HD 4600 with OCLP, which framebuffer patch is incorrect? Could you give me a clue or please send me your edited config.plist that suitable....
See the Framebuffer patching guide.
Follow your guide to patch, but yet to usb mapping. Here i attached my latest config.plist, please correct it
What correction you want to make?
Just doing USB mapping and my Bluetooth Dongle TP-Link UB 400 just work with bluetoolfix.kext. to inform, I'm connecting my HP Prodesk 600 G1 Mini with VGA monitor with DP to VGA adaptor.
I don't know whether my config.plist still having errors or not cause for now it's working good, so maybe you could correct my config.plist.
Thankyou for your help & patient...
You were mentioned to fix the Framebuffer patching only. Rest was fine.
yes, as of now, I consider its working great.. thanks for your support
Great. Marking Solved and closing this thread.
djalal548
