Can I hackintosh my HP Laptop 15s-eq2504sa? (AMD)
Im pretty sure many hp laptops only support some realtek wifi cards and the intel ax200 non vpro (L35282-005) , the vpro and every other intel wifi card is blacklisted.
Depends on the model and generation. Most of the Laptops and AIOs till 5th Gen had some WiFi blacklisted but since 6th Gen, that has not been the case. If your system has a blacklist, then use a re-branded card and that should work fine.
I'm almost certain these are the only 4 wifi cards that the hp 15s-eq laptops can officially use, the rest are blacklisted from the bios.many have mentioned that only the intel ax200 non vpro (L35282-005) works and not other ax200 variants and couldnt make the ax210 work at all
You can grab the third from top.
rubenuru
