Help with AMD Gigabyte Radeon R9 270 on MacOS Monterey
Takuroshi
Asus P8Z68V-LX
Intel I5-2500K
Gigabyte R9 270
12.x
  1. iMac Pro
Снимок экрана 2025-06-17 в 17.01.50.png Hello everyone! I’m having issues with my **Gigabyte R9 270 GPU** on macOS Monterey. I’ve tried many solutions to get it working, but so far without success. The most I’ve achieved is native monitor resolution and a non-laggy interface, **but without Metal support**. I’ve attached my OpenCore EFI folder.
View attachment 9579Hello everyone! I’m having issues with my **Gigabyte R9 270 GPU** on macOS Monterey. I’ve tried many solutions to get it working, but so far without success. The most I’ve achieved is native monitor resolution and a non-laggy interface, **but without Metal support**. I’ve attached my OpenCore EFI folder.
What's the native Device ID for the GPU?
Also, you shouldn't be using ATYInjector.kext.
I looked in the windows device manager, kext ATYInjector deleted
I tried to put 0x6811 id in deviceproperties and the interface became laggy and the monitor resolution was removed (it was 1024x768 when the id was 0x6810 1366x768)
UPD.
PCI\VEN_1002&DEV_6811&SUBSYS_226C1458&REV_00\4&80E7924&0&0008
UPD.
As indicated in the GPU compatibility guide, you'll have to spoof the Device ID for R9 270. The closest match would be 6810.
I fixed GPU by creating the correct SSDT-GPU-SPOOF, but this patch only worked with WhateverGreen version 1.5.1 (I learned this from a 3dogs1monkey guide on YouTube). Also, for some reason, the GPU name doesn't show up in "About This Mac," even though it displays correctly in other applications. how I can fix it? Attached my current EFI
Well, that's because you did not follow the correct guide. Use the latest WEG kext and grab the sample SSDT for spoofing from here. Note that you'll have to use SSDT-DTGP as well.
MacIntoshUser01
