amd 9800x3d Rx580 boot error
shangus
B650 AORUS ELITE AX V2
amd 9800x3d
rx580
15.x
Hello, I tried installing Sequire macos based on open core
I haven't been able to proceed for several days due to the error 514 successfully initialized ahci controller, please help me
amd 9800x3d
rx580
  • EFI.zip
    EFI.zip
amd 9800x3d
rx580
B650 AORUS ELITE AX V2View attachment 9547
For Ryzen 7000 series and newer, for some boards you'll have to map the MMIO Regions and fix the OEM ACPI.
Thank you for your answer.
mmio is already mapped
But I can't try because I don't have a tool to fix acpi
You can use MaciASL to fix.
As mentioned in the EFI guide creation:
Gigabyte B650 Motherboards with buggy BIOS
Base = \_SB.PCI0.GPP7
Find: 5F505257
Replace = 58505257
Comment = Rename GPP7 _PRW to XPRW
Enabled = YES
Find: 55503030
Replace = 55505858
Comment = Rename GPP7 _UP00 to UPXX
Enabled = YES
Add these two patches and then check. Regarding MMIO, here's the link to the guide:
Find: 5F505257
Replace = 58505257
Enabled = YES
Find: 55503030
Replace = 55505858
Enabled = YES
I tried to find about Gigabyte b650 in EFI guide and still can't find it. Can you provide me a link? Also, how to patch.
Find: 5F505257
Replace = 58505257
Enabled = YES
Find: 55503030
Replace = 55505858
Enabled = YES
Patches are not implemented.
XChikuX
