New Sequoia Installation
husker
Asus ROG Strix B650E-F Gaming WiFi
AMD Ryzen 9 7900x
AMD Radeon RX 6800
15.x
So like a couple others, I am getting a prohibited sign as well during the boot. I've previously had this working with Ventura, but just cannot get this working for the life of me... I've gone through the install guide several times, toying with the config.plist, adding a gpu disable, etc. Anybody know what could be going on? 1749189551018.png
So like a couple others, I am getting a prohibited sign as well during the boot. I've previously had this working with Ventura, but just cannot get this working for the life of me... I've gone through the install guide several times, toying with the config.plist, adding a gpu disable, etc. Anybody know what could be going on? View attachment 9519
Your EFI configuration is not as per the guide. Why are you using FixupAppleEfiImages?
You should consider disabling the APU from BIOS.
What's the state of Resize BAR in BIOS?
alvarg82
