Black screen after verbose
Yka
BMAX B6 Pro Mini
I5-1030NG7
Intel Iris Plus Graphics G7
15.x
Hello,
I am trying to install macos sequoia with an I5-1030NG7 and iGpu but i can't get past the verbose. Everytime the screen becomes black and nothing happens. I don't really know what to do and I don't know much about hackintoshes. I attached the EFI and log if it can help.
Hello,
What's your screen resolution and refresh rate? Also, what's the DVMT size?
It seems like the Framebuffer patching is not proper and a lot of parameters are missing.
Okay, I managed to complete the 1st part of the installation. I used Opcore simplify to make the EFI. Now i have a problem after the first part. I get a panic kernel. If i manually reboot i can see the apple logo with the loading bar but it stays stuck at "about 21 minutes remaining".
To answer your last question, i have 4k 60hz monitor and DVMT size at 128M
  • EFI.zip
    EFI.zip
Okay sequoia is installed but the only way to not have black screen is to use -igfxvesa in boot-args but i don't have graphic acceleration because of that. I've added framebuffer parameters but nothing changes
You have no connectors defined. You must patch the connectors. framebuffer-con0 enable, framebuffer-con0-type must be present for the internal screen to work. Also, you do not seem to have Backlight implementation which can also cause blackscreen. Add SSDT-PNLF and add the boot arg. Lastly, the ig-platform-id is wrong. It should be 0000528A.
While looking for a solution I saw that ice lake hackintoshes cannot use hdmi ports. My computer is not a laptop it’s the Bmax B6 pro and it only has hdmi ports. If I patch de connectors will it be possible to make the hdmi ports work ?
Yes, then it shouldn't be a problem. How many ports are there for display?
There is 2 HDMI ports and I have one Type-C which i can use too
Use con0, con1 and con2. Define these connectors and set HDMI for first two and then DP for the Type-C port. Reboot and check. Either one of the ports should give you display. You can login then and see what physical port resembles to conX port in IOReg.
dmitriy103
