Help HP Laptop Probook 445 G7 AMD Ryzen 5 4500U
makz
Gigabyte B450M-DS3H
AMD Ryzen 5 3600
Gigabyte AMD Radeon RX 570 4G
  1. iMac Pro
Hello, I have a laptop with the following configuration:
HP Probook 445 G7
AMD Ryzen 5 4500U zen 2 Renoir
Graphics integrated AMD Radeon RX Vega 6 (Ryzen 4000/5000)
16gb RAM
500Gb Nvme M.2 SSD
HP 8730 Board
Realtek sound driver (i dont know layout ID)
Realtek RTL8168/8111 LAN network
I created my EFI based on OC 1.0.0, taking the video on your YouTube channel for AMD laptop as a guide, but when starting the USB it gets stuck in "In memory panic stackshot succeeded match reboot", can you please help me correct my EFI in case this is the problem, thank you very much in advance.
HP Probook 445 G7
16gb RAM
500Gb Nvme M.2 SSD
HP 8730 Board
Any updates on this? I was able to get pass this but end up in a prohibit sign. My laptop is identical to yours.
Did you revise the EFI?
Did multiple times and it really drove me crazy. But later after a BIOS update it resolved itself. I think BIOS updates are critical to solving those no hint issues.
Yes, as per the guide, one should have the latest BIOS update installed.
Problem solved?
NCC74656
