Fenvi HB-1200M Wi-Fi not working
Yes, unfortunately it still doesn't work. I don't understand what else can be done.
If you reboot into Windows 11, Wi-Fi and Bluetooth work properly after installing the drivers.
Did you update the kexts and re-ran OCLP? Either way, attach the IOReg+EFI and System Report.
All kexts have been updated and re-ran OCLP, I have also attached the information that you requested from me in screenshots below:
You must attach the proper files. Not screenshots.
1) IOReg;
2) EFI;
3) System Report.
Please forgive me, I misunderstood you at first, but I have downloaded all the files and am attaching them as you asked. I am attaching everything in one archive, otherwise the site would not allow me to upload it.
1) IOReg;
2) EFI;
3) System Report.
Disable AirPortBrcmFixup and the child kexts and then check
Sorry for the long reply. I did as you said, screenshot below, but it still doesn't work.
alvarg82
