Sleep works but randomly my pc wake up and goes in sleep 1 minute later
I’ve done what you said. I replaced Mac Pro to iMac20,1 in usb ports. I didn’t change the SMBIOS and disabled Xhciportslimits. It works, but after, when I select SMBIOS update mode to create and make one for iMac20,1, after reboot no usb is working
Attach the PR Files to check.
Here it is.
Here it is.
Looks good. You must remove the kexts that are not required by your system.
Are the USB ports functional now?
I’ll do it tomorrow when I’ll return at home. The problem is only when I change SMBIOS, I don’t know why but it is only with this change (even with create mode and the same SMBIOS). I need to boot on USB with the old EFI to make the USB works when SMBIOS is changed) Can you just tell me which kexts I need to remove for my system?
Firstly, the irrelevant Ethernet kexts.
Sorry for the waiting but which one do I need to delete ? It was a pre build EFI and I had that when I used it. I think it’ll be better to recreate completely an another EFI with everything I need. If it’s the best way for you, I want some help to do that.
Yes, that's the best way. Check PM.
ploukop
