Wifi/Bt Dongle Buying Advice (Mac Os 15.2)
As expected, this is M.2 NGFF, A+E Key Type. The correct replacement card for Broadcom would be BCM94360NG.
i cant get it in germany though will the other one still work?
i cant get the ng but wouldnt the z4 still work anyway?
the previous ebay link i sent
but they are in that package so i can lay them out but the chipset is BCM94360 right so it should work right?
Does that mean you have already bought it? The main question is how will connect four antennas?
yeah but it comes in a week or so in the pictures theres 4 antennas
Write your reply...
sanaakram
