Sleep works but randomly my pc wake up and goes in sleep 1 minute later
swixiiii
Gigabyte H410m V2
i5-10400f
Sapphire Radeon RX 570 8gb
Hello, I recently changed my gpu to a RX 570 8gb to fix black screen issue with my Nvidia GPU. I removed old patch from OCLP and removed bootargs (ngfxcompat, nvda_drv) Sleep works good, it can wake up from usb and power button but sometimes, for no reason, even with every USB disconnected. It wakes up but with no display, like randomly I hear fans starting. I already disabled wake on lan, updated bios to the latest version available. I disabled Power Nap. Nothing changed.
Provide the updated system specs and attach PR Files to check!
What’s PR file?
My specs are :
Gigabyte H410m-V2
Intel i5-10400f
16gb ddr4 3600mhz RAM
240gb ADATA SSD (MacOS)
1tb Toshiba HDD (Storage)
320gb no name HDD (for Time Machine)
Fenvi FV T-919
And if you think it’s Time Machine, I disabled it to see if it was the problem.
What’s PR file?
PR Files are Problem Reporting Files. For more information, read the FAQ thread below:
Attach PR Files to check!
Here it is. Sorry I didn’t see you answered.
Why are you blindly injecting Ethernet kexts? You should use only as per your hardware. Ports seems to be mapped and yet you're using XhciPortLimit.
SMBIOS should not be set to custom. The Revpatch isn't implemented properly and other few issues exists as well.
Set ResizeAppleGpuBars to -1 and then check.
I’ve changed SMBIOS to overwrite, and I’ve done the resizeapplegpubars to -1. The problem is when I disable xHCIportslimit, no usb is working and I remapped usb 3 times to be sure
I also saw that when I change SMBIOS, no usb is working even if I stay on iMac20,1. WiFi is also working when I boot on EFI in my usb but when I replace EFI in System partition, it connects to WiFi without internet
Should be set to Create.
Disable it in the BIOS as well.
Indicates problem with the USB mapping. The reason why it doesn't work is because, the USBPorts.kext has MacPro7,1 and you're using iMac20,1. Simply, change the MacPro7,1 line to iMac20,1 and the ports should be in action.
You must fix the SMBIOS in the USBPorts.kext first.
xxxxxxxxxx
